Aggiornamento: RJ TextEd Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | RJ TextEd 12.10 Link winPenPack Aggiornamento dalla versione 12.06 alla 12.10 Home: -Link- Direct link portable: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | RJ TextEd 12.20 Link winPenPack Aggiornamento dalla versione 12.10 alla 12.20 Home: -Link- Direct link portable: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | RJ TextEd 12.30 Link winPenPack Aggiornamento dalla versione 12.20 alla 12.30 Home: -Link- Direct link portable: -Link- Risultato test: niente da segnalare | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | RJ TextEd 12.31 Link winPenPack Aggiornamento dalla versione 12.30 alla 12.31 Home: -Link- Direct link portable: -Link- Nota Il file portable ha la rel. 12.30 e quindi è necessario scaricare il file di aggiornamento alla ver 12.31: - Update files (v12.31) - install: -Link- - Update files (v12.31) - archive: -Link- What's New: (from Forum -Link- ) New in this version: ----------------------------------------------------------- Version 12.31 (Sep 3, 2017) ----------------------------------------------------------- Fixed * Font issue in search result panel. * Editor undo issue. * FTP tree issue. * File explorer issue. * File Commander issues. * A few split window issues. * Several FTP issues. * Several reported exceptions (error messages). This version is available. Install using the auto update feature or download (archive) from -Link- [ Edited Mon 13 Sep 2021 - 20:46 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | RJ TextEd 14.72 Link winPenPack -Link- Aggiornamento dalla versione 12.30 alla 14.72 Home: -Link- Download page: -Link- FossHub repository for RJ TextEd: -Link- Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 14.70: -Link- Signature for 'TextEd 32-bit + 64-bit Windows Portable':
'TextEd 32-bit + 64-bit Windows Portable' size: 157 MB Nota Il file portable ha la rel. 14.70 e quindi è necessario scaricare il file di aggiornamento alla ver. 14.72: - Update files (v14.72) Portable: -Link- What's New: (from Forum -Link- ) New in this version: ----------------------------------------------------------- Version 14.72 (February 17, 2021) ----------------------------------------------------------- Misc * Arabic was added to the list of available languages. * Cpp syntax file was updated. Fixed * SFTP issues when changing remote directory. * Lorem Ipsum in HTML menu could not be translated. * Exit compare mode error. * Change case functions in multi selection mode. * A startup issue where some file may not be accessible. * Minor issues in the Regular expression Creator. * Dual view action issue. * Error in customize keyboard shortcut window. * Redraw issue when a panel is hidden to a side. * Current file path in explorer panel toolbar should work now. * Delete issue when external document is visible (tab dragged outside the document area). * Save All enable issue when using multiple document views. * Close bracket issue in style section. By The Way L'autore di RJ TextEd (Rickard Johansson) si deve essere accorto che il suo editor ha raggiunto una dimensione 'monstre' e sta lavorando ad una versione Lite, cioè molto più leggera. • RJ TextEd Forum: -Link- • MPad (RJ Texted Lite): -Link- -> in questa discussione l'autore sta cercando un nome appropriato per la nuova versione Lite. | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | RJ TextEd 15.00 Link winPenPack -Link- Aggiornamento dalla versione 14.72 alla 15.00 Home: -Link- Download page: -Link- FossHub repository for RJ TextEd: -Link- Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.00: -Link- Local help file (2021-07-10): -Link- Nota La versione corrente è tuttavia la 15.0.3 rilasciata il 16 luglio 2021, ma non è ancora stata caricata su FossHub. RJ-TextEd versione corrente: La versione corrente 15.00 (15.0.3) è per Windows 7, 8.1, 10. Windows XP/Vista/Linux(Wine) (version 15.0.3): Questa versione è stata compilata con una vecchia versione di Delphi. -> download portable: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | RJ TextEd 15.10 Link winPenPack -Link- Aggiornamento dalla versione 15.00 alla 15.10 Home: -Link- Download page: -Link- FossHub repository for RJ TextEd: -Link- Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.10: -Link- Local help file (2021-08-28): -Link- Nota RJ-TextEd versione corrente: La versione corrente 15.10 è per Windows 7, 8.1, 10. Windows XP/Vista/Linux(Wine) (version 15.10): Questa versione è stata compilata con una vecchia versione di Delphi. -> download portable: -Link- [ Edited Thu 09 Sep 2021 - 12:07 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | RJ TextEd 15.20 Link winPenPack -Link- Aggiornamento dalla versione 15.10 alla 15.20 Home: -Link- Download page: -Link- FossHub repository for RJ TextEd: -Link- Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.20: -Link- Local help file (2021-10-04): -Link- Nota RJ-TextEd versione corrente: La versione corrente 15.20 è per Windows 7, 8.1, 10. Windows XP/Vista/Linux(Wine) (version 15.20): Questa versione è stata compilata con una vecchia versione di Delphi. -> download portable: -Link- [ Edited Tue 05 Oct 2021 - 21:07 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | RJ TextEd 15.22 Link winPenPack -Link- Aggiornamento dalla versione 15.20 alla 15.22 Home: -Link- Download page: -Link- FossHub repository for RJ TextEd: -Link- Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.22: -Link- Update file: Installer Portable (15.22) Local help file (2021-10-04): -Link- Nota RJ-TextEd versione corrente: La versione corrente 15.22 è per Windows 7, 8.1, 10. Windows XP/Vista/Linux(Wine) (version 15.20): Questa versione è stata compilata con una vecchia versione di Delphi. -> download portable: -Link- Update file: Installer Portable (15.22) [ Edited Thu 21 Oct 2021 - 16:27 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | RJ TextEd 15.23 Link winPenPack -Link- Aggiornamento dalla versione 15.22 alla 15.23 Home: -Link- Download page: -Link- FossHub repository for RJ TextEd: -Link- Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.23: -Link- Update file: Installer Portable (15.23) Local help file (2021-11-08): -Link- Nota RJ-TextEd versione corrente: La versione corrente 15.23 è per Windows 7, 8.1, 10. Windows XP/Vista/Linux(Wine) (version 15.20): Questa versione è stata compilata con una vecchia versione di Delphi. -> download portable: -Link- Update file: Installer Portable (15.23) [ Edited Tue 09 Nov 2021 - 08:30 ] | ||
