Aggiornamento: Iperius Backup
Go to page   <<        >>
Sat 24 Jun 2017 - 13:44
Registered Member #675
Iperius Backup 4.9.4
Link winPenPack
Aggiornamento dalla versione 4.9.2 alla 4.9.4
Home: -Link-
Direct link: -Link-
What's new: -Link-
Sun 23 Jul 2017 - 02:20
Iperius Backup 5.0.0
Link winPenPack
Aggiornamento dalla versione 4.9.4 alla 5.0.0
Home: -Link-
Direct link: -Link-
What's new: -Link-
Fri 18 Aug 2017 - 22:54
Iperius Backup 5.0.2
Link winPenPack
Aggiornamento dalla versione 5.0.0 alla 5.0.2
Home: -Link-
Direct link: -Link-
What's new: -Link-
Sat 02 Sep 2017 - 15:27
Iperius Backup 5.0.4
Link winPenPack
Aggiornamento dalla versione 5.0.2 alla 5.0.4
Home: -Link-
Direct link: -Link-
What's new: -Link-
rbon
Tue 14 Apr 2020 - 19:28
Registered Member #4134
Iperius Backup 7.0.5
Link winPenPack -Link-
Aggiornamento dalla versione 5.0.4 alla 7.0.5
web site: -Link-
download page: -Link-
direct download free: -Link-
What's New (Change Log): -Link-
Confronta versioni di Iperius Backup: -Link-
Come ottenere la versione portable:
1. Estrarre l'installer 'SetupIperius.exe' con InnoEx 0.9.2 -Link-
2. selezionare tutti i files contenuti nella cartella {app}
3. estrarli nella nuova cartella 'Iperius Backup Portable'
4. fatto
[ Edited Tue 14 Apr 2020 - 19:33 ]
rbon
Sat 30 May 2020 - 19:22
Iperius Backup 7.0.8
Aggiornamento dalla versione 7.0.5 alla 7.0.8
web site: -Link-
What's New (Change Log) del 25/05/2020: -Link-
New features
• Iperius Backup is compatible with VMware ESXi 7
• SQL Server backup: Iperius now supports TLS 1.2 encrypted connection
• SQL Server backup: now the compressed size is also shown in the log when native compression is enabled
• ESXi configuration: now the default backup is the incremental one (CBT / VDDK)
• Added new command line parameter to run a job as a service
• SQL Server: now the software better manages the switch between native compression enabled and disabled, showing a warning when the backup set is reinitialized
• Several improvements and optimizations
-> Softpedia.com link: -Link-
4. fatto
rbon
Fri 24 Jul 2020 - 18:21
Iperius Backup 7.0.9
Aggiornamento dalla versione 7.0.8 alla 7.0.9
web site: -Link-
What's New (Change Log) del 26/06/2020: -Link-
-> Softpedia.com: -Link-
4. fatto
P.S.
@Danix
nella pagina di download -Link- viene riportata come versione da scaricare:
ver. 5.0.8 anzichè ver. 7.0.8 (ver. 7.0.9 dopo l'aggiornamento).
Pregasi correggere
Sat 25 Jul 2020 - 10:53
rbon wrote ...
cut
@Danix
Pregasi correggere
Fatto! Grazie per l'avvertimento
rbon
Sun 27 Sep 2020 - 20:25
Iperius Backup 7.1.1
Aggiornamento dalla versione 7.0.9 alla 7.1.1
web site: -Link-
What's New (Change Log) del 22/09/2020: -Link-
Nota_1
La versione Free NON consente l'aggiornamento automatico: bisogna scaricare la nuova versione e sostituire la precedente.
Nota_2
per ottenere la versione portable (dall'installer scaricato):
4. fatto
rbon
Thu 15 Oct 2020 - 20:14
Iperius Backup 7.1.2
Aggiornamento dalla versione 7.1.1 alla 7.1.2
web site: -Link-
What's New (Change Log) del 01/10/2020: -Link-
Nota_1
Nota_2
4. fatto
Go to page   <<        >>
