Aggiornamento: Notepad++ Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Notepad++ 7.5 Link winPenPack Aggiornamento dalla versione 7.4.2 alla 7.5 Home: -Link- Direct Link (32 bit) -Link- Direct Link (64 bit): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Notepad++ 7.5.1 Link winPenPack Aggiornamento dalla versione 7.5 alla 7.5.1 Home: -Link- Direct Link (32 bit) -Link- Direct Link (64 bit): -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1696 | Notepad++ 7.8.7 Link winPenPack Aggiornamento dalla versione 7.5.1 alla 7.8.7 Home: -Link- Direct Link (32 bit): -Link- Direct Link (64 bit): -Link- [ Edited Wed 17 Jun 2020 - 11:29 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Notepad++ 7.9.1. Link winPenPack -Link- Aggiornamento dalla versione 7.8.9 alla 7.9.1 web site: -Link- download page: -Link- direct link portable 32 bit (zip): -Link- direct link portable 64 bit (zip): -Link- Nota: questa versione contiene 29 fra miglioramenti e correzione di errori ! vedi elenco sulla pagina di download. | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1696 | Notepad++ 7.9.2 Link winPenPack Aggiornamento dalla versione 7.9.1 alla 7.9.2 web site: -Link- download page: -Link- direct link portable 32 bit (zip): -Link- direct link portable 64 bit (zip): -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1696 | Notepad++ 7.9.3 Link winPenPack Aggiornamento dalla versione 7.9.2 alla 7.9.3 web site: -Link- download page: -Link- direct link portable 32 bit (zip): -Link- direct link portable 64 bit (zip): -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Notepad++ 7.9.4 Link winPenPack -Link- Aggiornamento dalla versione 7.9.3 alla 7.9.4 web site: -Link- GitHub - project page: -Link- GitHub - download page: -Link- direct link portable 32 bit (zip): -Link- direct link portable 64 bit (zip): -Link- Changelog for ver. 7.9.4: -Link- Plugins: GitHub Plugin List - page: -Link- GitHub Plugin List - 32 bit: -Link- GitHub Plugin List - 64 bit: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1696 | Notepad++ 7.9.5 Link winPenPack -Link- Aggiornamento dalla versione 7.9.4 alla 7.9.5 web site: -Link- GitHub - project page: -Link- GitHub - download page: -Link- direct link portable 32 bit (zip): -Link- direct link portable 64 bit (zip): -Link- Changelog for ver. 7.9.5: -Link- Plugins: GitHub Plugin List - page: -Link- GitHub Plugin List - 32 bit: -Link- GitHub Plugin List - 64 bit: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Notepad++ 8.0 Link winPenPack -Link- Aggiornamento dalla versione 7.9.5 alla 8.0 web site: -Link- GitHub - project page: -Link- GitHub - download page: -Link- direct link portable 32 bit (zip): -Link- direct link portable 64 bit (zip): -Link- Changelog for ver. 8.0: -Link- Plugins: GitHub Plugin List - page: -Link- GitHub Plugin List - 32 bit: -Link- GitHub Plugin List - 64 bit: -Link- Notepad++ 8.0 32-64 bit Multilingual by PortableAppZ: Notepad++ page on blog: -Link- Notepad++ Portable 32-64 bit 8.x Online installer: -Link- By The Way: se utilizzate il launcher di PortableAppZ, dopo l'installazione della versione Portable, ricordatevi di copiare il file 'nppPluginList.dll': • dalla cartella: C:\PortableApps\Notepad++Portable\Data\Notepad++\plugins\Config • alla cartella: C:\PortableApps\Notepad++Portable\App\Notepad++\plugins\Config in quanto, per un difetto del nuovo launcher relativo alla versione 8.x, la DLL 'nppPluginList.dll' non viene copiata nella posizione corretta e quindi, dopo che aggiornate un plugin (ad esempio AutoSave alla ver. 1.6.1) scompare la voce (item) 'Gestione plugin...) dal menu 'Plugin'. Probabilmente la voce Gestione plugin... scompare dopo ogni aggiornamento di plugins: stesso difetto che era presente nella versione di Notepad++ Portable di Portableapps (solo a 32 bit!) -Link- . [ Edited Tue 08 Jun 2021 - 19:13 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Notepad++ 8.1 Link winPenPack -Link- Aggiornamento dalla versione 8.0 alla 8.1 web site: -Link- GitHub - project page: -Link- GitHub - download page: -Link- direct link portable 32 bit (zip): -Link- direct link portable 64 bit (zip): -Link- Changelog for ver. 8.1: -Link- Release date: June 17, 2021 Plugins: GitHub Plugin List - page: -Link- GitHub Plugin List - 32 bit: -Link- GitHub Plugin List - 64 bit: -Link- | ||
