X-Launcher for Software Update Monitor (SUMo)
ak1969
Thu 15 Jan 2009 - 13:18
Registered Member #16312
Hello,
if somebody is interested I wrote a launcher for a small program that I find very useful for keeping the software I have on the portable USB media up-to-date. Here it is:
Software name: SUMo
Direct Link to download: -Link-
File size: 1500 Kb
Author's name: (if present) KC Softwares
Author's eMail: (if present)
Author's Website: -Link-
Description:
SUMo, which stands for Software Update Monitor. Thanks to SUMo you'll be able to keep your PC up-to-date by using the most recent version of your favorite software ! Unlike build-in auto update features, SUMo tells you if updates are available before you need to use your software.
Features
* Automatic detection of installed software
* Detects required updates / patchs for your software
* Filter / authorize Beta versions (user setting)
* Ignore list : only tracks software YOU want to track
* More compatibility and less false positive than others Update Monitors (according to users feedback
* Internationalization support.
Portable tips how-to: use the provided x-launcer X-SUMo
- extract the folder SUMo into X-SUMo\Bin (so as to have X-SUMo\Bin\SUMo)
- run X-SUMo.exe
Version:
X-SUMo launcher 1.3.1 ini rev1 (tested with SUMo 2.4.1.67)
License: SUMo is freeware (but not opensource)
ak1969
[removed]
[ Edited Thu 15 Jan 2009 - 13:28 ]
Thu 15 Jan 2009 - 13:31
As I have already said by e-mail, SUMo is not an open source program.
Therefore is not possible to link a modified version (or a launcher) on winPenPack.com, neither it is possible to portabilize (modifiy) it without author's permission.
I had to remove the launcher.
Please, search the corresponding open source program, portabilize it and share it with winPenPack community. Thank you for your collaboration.
[ Edited Thu 15 Jan 2009 - 13:39 ]
ak1969
Thu 15 Jan 2009 - 15:53
I'm sorry about this
I did not understand well your first email... I thought that posting a launcher without including the software itself was OK.
Kyle_Katarn
Sun 19 Aug 2012 - 15:41
Registered Member #40651
SUMo now have a portable version that CAN be included in your package.
Kyle - SUMo lead developper
dito
Sun 19 Aug 2012 - 17:03
Registered Member #11533
Appupdater potrebbe essere una alternativa open source.
Esiste una versione portabile creata in stile Portableapps; questo il link al download: -Link-
Questo il link ad una discussione relativa alla portabilizzazione ospitata su Portablefreeware: -Link-
Questa la pagina web su Surgeforge: -Link-
Homepage: -Link-
Winapp_manager è una seconda alternativa, sempre open source.
Esiste una versione portabile; questo il link al download: -Link-
Homepage: -Link-
[ Edited Sun 19 Aug 2012 - 21:21 ]
Kyle_Katarn
Wed 26 Jun 2019 - 00:44
SUMo - 5.9.4 (Released 2019-06-26)
wrote ...
0005495: [Bug] SUMo starting with incomplete status text line (Kyle_Katarn)
0004239: [Refactoring] SUMo shall filter "DTS Post Processing APO" (Kyle_Katarn)
0005530: [Bug] "IOBit Uninstaller Portable" incorrectly detected as "IOBit Uninstaller" (Kyle_Katarn)
0005248: [Bug] Malwarebytes Corporate wrong update channel (Kyle_Katarn)
0005546: [Refactoring] Refactor "Steam Installer" (Kyle_Katarn)
0005540: [Refactoring] Updated Italiant translation (Kyle_Katarn)
rbon
Fri 05 Jul 2019 - 23:30
Registered Member #4134
Kyle_Katarn wrote ...
b.t.w.
there is a portable version of this freeware made by John T. Haller (Portableapps.com):
1. SUMo portable: -Link-
2. program version: 5.9.4.424
3. paf size: 2 MB
4. program installed: 6 MB
Surely he (John T. Haller) got permission from the author to build a portable with paf installer.
Kyle_Katarn
Tue 30 Jul 2019 - 20:35
SUMo - 5.9.5 (Released 2019-07-30)
wrote ...
0005603: [Bug] "Search [...]" popup menu item not available for translation (Kyle_Katarn)
0005588: [Refactoring] Consolidate / Rationalize Multi Commander reporting (Kyle_Katarn)
0005597: [Refactoring] "POIbase powered by:" to be renamed "POIbase" (Kyle_Katarn)
0005592: [Bug] "DMDE" product naming to be reworked (embedding version number) (Kyle_Katarn)
0005598: [Refactoring] "WebGear Ltd" company name rationalization (Kyle_Katarn)
0005591: [Refactoring] "cURL" company name rationalization (Kyle_Katarn)
0005564: [Refactoring] Product name starting by "installs " to be filtered out (Kyle_Katarn)
0005602: [Refactoring] Updated Hungarian translation (Kyle_Katarn)
rbon
Wed 31 Jul 2019 - 22:31
In my opinion You do not must update this discussion because winPenPack do not develop a portable version of SUMo.
In effect someone has already posted this update on PortableApps.
Please see inside:
-> PortableApps.com -> Development -> Outdated Official Portable Applications: -Link-
rbon
Wed 31 Jul 2019 - 22:48
I have found on Softpedia Portable SUMo at this page: -Link-
En effect if You browse on KC Softwares at Download page, You may find SUMo Portable (file sumo.zip) at this link -Link-
