Aggiornamento: X-7Zip Go to page << |
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | X-7-Zip 22.00 Link winPenPack Aggiornamento dalla versione 21.07 alla 22.00 Home: -Link- Sourceforge download page: -Link- Direct Link: (32-bit): (non portatile) -Link- Direct Link: (64-bit): (non portatile) -Link- Changerlog • 7-Zip now can extract APFS (Apple File System) images that can be used in DMG files. • 7-Zip now can create TAR archives in POSIX (pax) tar format with the switches -ttar -mm=pax or -ttar -mm=posix • 7-Zip now can store additional file timestamps with high precision (1 ns in Linux) in tar/pax archives with the following switches: -ttar -mm=pax -mtp=3 -mtc -mta • New switches for Linux version for TAR archives: -snoi : store owner/group ids in archive or set owner/group ids from archive to extracted files. -snon : store owner/group names in archive • New -snz switch to propagate Zone.Identifier stream to extracted files (Windows). • New option "Propagate Zone.Id stream" in Tools/Options/7-Zip menu. • New "Options" window in "Add to archive" allows to select what metadata must be included to archive. Also it allows to select new option "Do not change source files last access time". • Some bugs were fixed. | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1697 | X-7-Zip 22.01 Link winPenPack Aggiornamento dalla versione 22.00 alla 22.01 Home: -Link- Sourceforge download page: -Link- Direct Link: (32-bit): (non portatile) -Link- Direct Link: (64-bit): (non portatile) -Link- Changerlog - UDF support was improved to UDF version 2.60. - HFS and APFS support was improved. [ Edited Fri 22 Jul 2022 - 12:54 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1697 | X-7-Zip 23.01 Link winPenPack Aggiornamento dalla versione 22.01 alla 23.01 Home: -Link- Sourceforge download page: -Link- Direct Link: (32-bit): (non portatile) -Link- Direct Link: (64-bit): (non portatile) -Link- Changerlog - The page "Language" in 7-Zip's menu Tools/Options now shows information about selected translation, including the number of translated lines. - Some bugs were fixed - 7-Zip now can use new ARM64 filter for compression to 7z and xz archives. ARM64 filter can increase compression ratio for data containing executable files compiled for ARM64 (AArch64) architecture. Also 7-Zip now parses executable files (that have exe and dll filename extensions) before compressing, and it selects appropriate filter for each parsed file: - BCJ or BCJ2 filter for x86 executable files, - ARM64 filter for ARM64 executable files. Previous versions by default used x86 filter BCJ or BCJ2 for all exe/dll files. - Default section size for BCJ2 filter was changed from 64 MiB to 240 MiB. It can increase compression ratio for executable files larger than 64 MiB. - UDF: support was improved. - cpio: support for hard links. - Some changes and optimizations in WIM creation code. - When new 7-Zip creates multivolume archive, 7-Zip keeps in open state only volumes that still can be changed. Previous versions kept all volumes in open state until the end of the archive creation. - 7-Zip for Linux and macOS now can reduce the number of simultaneously open files, when 7-Zip opens, extracts or creates multivolume archive. It allows to avoid the failures for cases with big number of volumes, bacause there is a limitation for number of open files allowed for a single program in Linux and macOS. - There are optimizations in code for 7-Zip's context menu in Explorer: the speed of preparing of the menu showing was improved for cases when big number of files were selected by external program for context menu that contains 7-Zip menu commands. - There are changes in code for the drag-and-drop operations to and from 7-Zip File Manager. And the drag-and-drop operation with right button of mouse now is supported for some cases. - The bugs were fixed: - ZIP archives: if multithreaded zip compression was performed with more than one file to stdout stream (-so switch), 7-zip didn't write "data descriptor" for some files. - ext4 archives: 7-Zip couldn't correctly extract symbolic link to directory from ext4 archives. - HFS and APFS archives: 7-Zip incorrectly decoded uncompressed blocks (64 KiB) in compressed forks. - Some another bugs were fixed. [ Edited Wed 28 Jun 2023 - 19:36 ] | ||
Go to page <<
