Aggiornamento: Iperius Backup Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Iperius Backup 4.9.4 Link winPenPack Aggiornamento dalla versione 4.9.2 alla 4.9.4 Home: -Link- Direct link: -Link- What's new: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Iperius Backup 5.0.0 Link winPenPack Aggiornamento dalla versione 4.9.4 alla 5.0.0 Home: -Link- Direct link: -Link- What's new: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Iperius Backup 5.0.2 Link winPenPack Aggiornamento dalla versione 5.0.0 alla 5.0.2 Home: -Link- Direct link: -Link- What's new: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Iperius Backup 5.0.4 Link winPenPack Aggiornamento dalla versione 5.0.2 alla 5.0.4 Home: -Link- Direct link: -Link- What's new: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Iperius Backup 7.0.5 Link winPenPack -Link- Aggiornamento dalla versione 5.0.4 alla 7.0.5 web site: -Link- download page: -Link- direct download free: -Link- What's New (Change Log): -Link- Confronta versioni di Iperius Backup: -Link- Come ottenere la versione portable: 1. Estrarre l'installer 'SetupIperius.exe' con InnoEx 0.9.2 -Link- 2. selezionare tutti i files contenuti nella cartella {app} 3. estrarli nella nuova cartella 'Iperius Backup Portable' 4. fatto [ Edited Tue 14 Apr 2020 - 19:33 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Iperius Backup 7.0.8 Link winPenPack -Link- Aggiornamento dalla versione 7.0.5 alla 7.0.8 web site: -Link- download page: -Link- direct download free: -Link- Confronta versioni di Iperius Backup: -Link- What's New (Change Log) del 25/05/2020: -Link- New features • Iperius Backup is compatible with VMware ESXi 7 • SQL Server backup: Iperius now supports TLS 1.2 encrypted connection • SQL Server backup: now the compressed size is also shown in the log when native compression is enabled • ESXi configuration: now the default backup is the incremental one (CBT / VDDK) • Added new command line parameter to run a job as a service • SQL Server: now the software better manages the switch between native compression enabled and disabled, showing a warning when the backup set is reinitialized • Several improvements and optimizations Come ottenere la versione portable: 1. Estrarre l'installer 'SetupIperius.exe' con InnoEx 0.9.2 -> Softpedia.com link: -Link- 2. selezionare tutti i files contenuti nella cartella {app} 3. estrarli nella nuova cartella 'Iperius Backup Portable' 4. fatto | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Iperius Backup 7.0.9 Link winPenPack -Link- Aggiornamento dalla versione 7.0.8 alla 7.0.9 web site: -Link- download page: -Link- direct download free: -Link- Confronta versioni di Iperius Backup: -Link- What's New (Change Log) del 26/06/2020: -Link- Come ottenere la versione portable: 1. Estrarre l'installer 'SetupIperius.exe' con InnoEx 0.9.2 -> Softpedia.com: -Link- 2. selezionare tutti i files contenuti nella cartella {app} 3. estrarli nella nuova cartella 'Iperius Backup Portable' 4. fatto P.S. @Danix nella pagina di download -Link- viene riportata come versione da scaricare: ver. 5.0.8 anzichè ver. 7.0.8 (ver. 7.0.9 dopo l'aggiornamento). Pregasi correggere | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | rbon wrote ... cut @Danix nella pagina di download -Link- viene riportata come versione da scaricare: ver. 5.0.8 anzichè ver. 7.0.8 (ver. 7.0.9 dopo l'aggiornamento). Pregasi correggere Fatto! Grazie per l'avvertimento | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Iperius Backup 7.1.1 Link winPenPack -Link- Aggiornamento dalla versione 7.0.9 alla 7.1.1 web site: -Link- download page: -Link- direct download free: -Link- Confronta versioni di Iperius Backup: -Link- What's New (Change Log) del 22/09/2020: -Link- Nota_1 La versione Free NON consente l'aggiornamento automatico: bisogna scaricare la nuova versione e sostituire la precedente. Nota_2 per ottenere la versione portable (dall'installer scaricato): 1. Estrarre l'installer 'SetupIperius.exe' con InnoEx 0.9.2 -> Softpedia.com: -Link- 2. selezionare tutti i files contenuti nella cartella {app} 3. estrarli nella nuova cartella 'Iperius Backup Portable' 4. fatto | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Iperius Backup 7.1.2 Link winPenPack -Link- Aggiornamento dalla versione 7.1.1 alla 7.1.2 web site: -Link- download page: -Link- direct download free: -Link- What's New (Change Log) del 01/10/2020: -Link- Nota_1 La versione Free NON consente l'aggiornamento automatico: bisogna scaricare la nuova versione e sostituire la precedente. Nota_2 per ottenere la versione portable (dall'installer scaricato): 1. Estrarre l'installer 'SetupIperius.exe' con InnoEx 0.9.2 -> Softpedia.com: -Link- 2. selezionare tutti i files contenuti nella cartella {app} 3. estrarli nella nuova cartella 'Iperius Backup Portable' 4. fatto | ||
