Aggiornamento: Uranium Backup
Go to page   <<        >>
Tue 26 Oct 2010 - 14:30
Registered Member #675
Uranium Backup 8.4.3 (Build 4381) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.2 (Build 4376) alla 8.4.3 (Build 4381)
Home: -Link-
Direct Link: -Link-
Risultato Test: Identico alle versioni precedenti
Mon 22 Nov 2010 - 21:45
Uranium Backup 8.4.5 (Build 4409) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.3 (Build 4381) alla 8.4.5 (Build 4409)
Home: -Link-
Direct Link: -Link-
[ Edited Wed 24 Nov 2010 - 21:12 ]
Tue 07 Dec 2010 - 20:50
Uranium Backup 8.4.6 (Build 4418) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.5 (Build 4409) alla 8.4.6 (Build 4418)
Home: -Link-
Direct Link: -Link-
[ Edited Tue 07 Dec 2010 - 21:49 ]
Thu 09 Dec 2010 - 21:20
Uranium Backup 8.4.6 (Build 4422) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.6 (Build 4418) alla 8.4.6 (Build 4422)
Home: -Link-
Direct Link: -Link-
Tue 14 Dec 2010 - 21:54
Uranium Backup 8.4.6 (Build 4424) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.6 (Build 4422) alla 8.4.6 (Build 4424)
Home: -Link-
Direct Link: -Link-
Sat 18 Dec 2010 - 21:55
Uranium Backup 8.4.7 (Build 4433) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.6 (Build 4424) alla 8.4.7 (Build 4433)
Home: -Link-
Direct Link: -Link-
Fri 11 Feb 2011 - 21:39
Uranium Backup 8.4.8 (Build 4453) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.7 (Build 4433) alla 8.4.8 (Build 4453)
Home: -Link-
Direct Link: -Link-
[ Edited Sun 13 Feb 2011 - 19:23 ]
Sat 12 Mar 2011 - 15:47
Uranium Backup 8.4.8 (Build 4458) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.8 (Build 4453) alla 8.4.8 (Build 4458)
Home: -Link-
Direct Link: -Link-
Risultato Test: Identico alle versioni precedenti.
[ Edited Tue 15 Mar 2011 - 14:35 ]
Tue 12 Apr 2011 - 15:41
Uranium Backup 8.4.9 (Build 4510) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.8 (Build 4458) alla 8.4.9 (Build 4510)
Home: -Link-
Direct Link: -Link-
[ Edited Wed 13 Apr 2011 - 21:19 ]
Fri 15 Apr 2011 - 15:06
Uranium Backup 8.4.9 (Build 4520) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit
Link winPenPack
Aggiornamento dalla versione 8.4.9 (Build 4510) alla 8.4.9 (Build 4520)
Home: -Link-
Direct Link: -Link-
[ Edited Fri 15 Apr 2011 - 20:02 ]
Go to page   <<        >>
