Aggiornamento: Uranium Backup Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.4.9 (Build 4537) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.4.9 (Build 4520) alla 8.4.9 (Build 4537) Home: -Link- Direct Link: -Link- Risultato Test: Identico alle versioni precedenti. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.4.9 (Build 4550) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.4.9 (Build 4537) alla 8.4.9 (Build 4550) Home: -Link- Direct Link: -Link- Risultato Test: Identico alle versioni precedenti. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.5.0 (Build 4581) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.4.9 (Build 4550) alla 8.5.0 (Build 4581) Home: -Link- Direct Link: -Link- Risultato Test: Identico alle versioni precedenti. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.6.0 (Build 4623) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.5.0 (Build 4581) alla 8.6.0 (Build 4623) Home: -Link- Direct Link: -Link- Risultato Test: Identico alle versioni precedenti. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.6.1 (Build 4646) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.6.0 (Build 4623) alla 8.6.1 (Build 4646) Home: -Link- Direct Link: -Link- Risultato test: | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.6.1 (Build 4663) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.6.1 (Build 4646) alla 8.6.1 (Build 4663) Home: -Link- Direct Link: -Link- Risultato Test: Identico alle versioni precedenti. [ Edited Tue 01 Nov 2011 - 21:14 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.6.2 (Build 4727) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.6.1 (Build 4663) alla 8.6.2 (Build 4727) Home: -Link- Direct Link: -Link- Risultato Test: Identico alle versioni precedenti. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.6.3 (Build 4744) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.6.2 (Build 4727) alla 8.6.3 (Build 4744) Home: -Link- Direct Link: -Link- Risultato Test: Identico alle versioni precedenti. [ Edited Tue 15 Nov 2011 - 21:39 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.6.3 (Build 4746) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.6.3 (Build 4744) alla 8.6.3 (Build 4746) Home: -Link- Direct Link: -Link- Risultato Test: Identico alle versioni precedenti. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Uranium Backup 8.6.4 (Build 4758) Windows XP / 2000 / 2003 / 2008 / Vista / 7 - 32 e 64 bit Link winPenPack Aggiornamento dalla versione 8.6.3 (Build 4746) alla 8.6.4 (Build 4758) Home: -Link- Direct Link: -Link- Risultato Test: Identico alle versioni precedenti. | ||
