Aggiornamento: CCleaner Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | CCleaner Portable 5.03.5128 Link winPenPack Aggiornamento dalla versione 5.02.5101 alla 5.03.5128 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | CCleaner Portable 5.04.5151 Link winPenPack Aggiornamento dalla versione 5.03.5128 alla 5.04.5151 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | CCleaner Portable 5.05.5176 Link winPenPack Aggiornamento dalla versione 5.04.5151 alla 5.05.5176 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
sceicco |
Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | CCleaner Portable v 5.06.5219 Link winPenPack Aggiornamento dalla versione 5.05.5176 alla 5.06.5219 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare [ Edited Tue 26 May 2015 - 23:42 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | CCleaner Portable 5.07.5261 Link winPenPack Aggiornamento dalla versione 5.05.5176 alla 5.07.5261 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | CCleaner Portable 5.08.5308 Link winPenPack Aggiornamento dalla versione 5.07.5261 alla 5.08.5308 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | CCleaner Portable 5.09.5343 Link winPenPack Aggiornamento dalla versione 5.08.5308 alla 5.09.5343 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare [ Edited Mon 31 Aug 2015 - 15:10 ] | ||
b9b9b9 |
Registered Member #264 Joined: Mon 22 Jan 2007 - 10:55Posts: 112 | Ciao a tutti... dopo tanto tempo, eccomi qui. Giusto per avvisare, ho notato che la versione portable nella pagina alternativa non e' piu' disponibile - solo exe: qualcuno puo' confermare? grazie | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | sistemato! Ma ora non è un vero "direct link" (infatti, puntando a: "www.piriform.com/ccleaner/download/portable" , il DL in realtà non funziona!), ti rimanda alla pagina da cui puoi, in seguito, scaricare la "portable" [ Edited Mon 31 Aug 2015 - 15:14 ] | ||
b9b9b9 |
Registered Member #264 Joined: Mon 22 Jan 2007 - 10:55Posts: 112 | Grazie taf! p.s. ho controllato, e la cosa funziona cosi' anche per gli altri programmi di piriform (defraggler/speccy/recuva) [ Edited Mon 31 Aug 2015 - 17:15 ] | ||
