Aggiornamento: X-HFS (Http File Server) Go to page >> |
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Http File Server 2.2 Build 120 Aggiornamento dalla versione 2.1d alla 2.2 Build 120 Home: -Link- Direct Link: -Link- [ Edited Tue 15 Jun 2010 - 09:38 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Http File Server 2.2a Build 124 Aggiornamento dalla versione 2.2 Build 120 alla 2.2a Build 124 Home: -Link- Direct Link: -Link- [ Edited Fri 24 Aug 2007 - 23:41 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Http File Server 2.2b Build 150 Link winPenPack Aggiornamento dalla versione 2.2a Build 124 alla 2.2b Build 150 Home: -Link- Direct Link: -Link- | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Http File Server 2.3 beta Build 171 Aggiornamento dalla versione 2.2b Build 150 alla 2.3 beta Build 171 Home: -Link- Direct Link: -Link- | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Http File Server 2.3 beta Build 174 Aggiornamento dalla versione 2.3 beta Build 171 alla 2.3 beta Build 174 Home: -Link- Direct Link: -Link- | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Http File Server 2.3 beta Build 177 Aggiornamento dalla versione 2.3 beta Build 174 alla 2.3 beta Build 177 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Http File Server 2.3 beta Build 178 Link winPenPack Aggiornamento dalla versione 2.3 beta Build 177 alla 2.3 beta Build 178 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Http File Server 2.3 beta Build 179 Link winPenPack Aggiornamento dalla versione 2.3 beta Build 178 alla 2.3 beta Build 179 Home: -Link- Direct Link: -Link- Test: (niente da segnalare) | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Http File Server 2.3 beta Build 180 Link winPenPack Aggiornamento dalla versione 2.3 beta Build 179 alla 2.3 beta Build 180 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare [ Edited Wed 27 Feb 2008 - 09:17 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Http File Server 2.3 beta Build 181 Link winPenPack Aggiornamento dalla versione 2.3 beta Build 180 alla 2.3 beta Build 181 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
