Aggiornamento: X-Thunderbird Go to page << >> |
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Nota / Note: [It] Release Bugfix - testato con vecchio launcher, niente da segnalare [En] Bugfix version - tested with existing launcher, works properly [ Edited Wed 07 Sep 2011 - 08:06 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 7.0 Link winPenPack (Multilingual) Aggiornamento dalla versione 6.0.2 alla 7.0 Home: -Link- Mirror (not portable): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 7.0.1 Link winPenPack (Multilingual) Aggiornamento dalla versione 7.0 alla 7.0.1 Home: -Link- Mirror (not portable): -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Sun 16 Oct 2011 - 20:00 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | NOTA (cancellabile): TESTATO! è una "minor release" e funziona perfettamente con il launcher precedente, basta modificare gli .ini! | ||
ktxgio |
Registered Member #19775 Joined: Fri 27 Mar 2009 - 16:22Posts: 11 | grazie [ Edited Tue 18 Oct 2011 - 19:54 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 8.0 Link winPenPack (Multilingual) Aggiornamento dalla versione 7.0.1 alla 8.0 Home: -Link- Mirror (not portable): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 9.0 Link winPenPack (Multilingual) Aggiornamento dalla versione 8.0 alla 9.0 Home: -Link- Mirror (not portable): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 9.0.1 Link winPenPack (Multilingual) Aggiornamento dalla versione 9.0 alla 9.0.1 Home: -Link- Mirror (not portable): -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Tue 27 Dec 2011 - 14:59 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 10.0 Link winPenPack (Multilingual) Aggiornamento dalla versione 9.0.1 alla 10.0 Home: -Link- Mirror (not portable): -Link- ** EDIT by Taf **: [It]OK - testato con vecchio launcher, niente da segnalare [En]OK - tested with existing launcher, works properly [ Edited Wed 01 Feb 2012 - 08:21 ] | ||
xymox |
Registered Member #20165 Joined: Mon 30 Mar 2009 - 08:45Location: parma Posts: 12 | ti rimanda sempre alla versione 9 | ||
