[moved] languages
MattN
Mon 12 Feb 2007 - 09:51
Registered Member #2662
Hi,
I just installed WinPenPack and although it runs, I don't know enough Italian to understand much of what I am looking atl. I thought I had selected English, but everything is being displayed in Italian. Did I do something wrong, or is there some way to get things to display in English?
The use of the pen drive for these functions is an AWESOME idea, but if it is for use in other countries, at least the instructions for using the program needs to be in that countries language. I hope you understand my problem and thanks in advance.
MattN
Mon 12 Feb 2007 - 10:10
Hi MattN,
Once You have installed Your WPP suite, go to TrayIcon, Left click on it, choose "Opzioni".
Then on "lingua" selection, please select English.
Now close Your WPP and Restart...
Now English is Your language!
IMPORTANT: the name of WPP Folders and their menunames are in italian anyway!
You can rename them by Yourself
FYI, have a look at this page: -Link-
BTW, if you want to see all site in English, at the right corner of the homepage you can select "english"..
I hope this helps!
[ Edited Mon 12 Feb 2007 - 13:12 ]
dot1910
Fri 07 Sep 2007 - 17:26
Registered Member #5995
Is there any chance to get X-launcher tutorial/FAQ in english ?
pls someone do it!
Fri 07 Sep 2007 - 18:20
Welcome to winPenpack dot1910
Sorry but no translation of tutorial is previewed at moment...perhaps for 2.0 X-Launcher version.
