Modifiche e aggiornamenti software da winPenPack 3.1 Go to page << >> |
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: JkDefrag 3.17 Win 2000/2003/XP/Vista Aggiornamento dalla versione 3.16 alla 3.17 Home: -Link- Direct Link: -Link- [ Edited Mon 27 Aug 2007 - 21:08 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Ini Update X-xCollect [rev3] -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | MediaCoder 0.6.0.3858 Link WinPenPack Aggiornamento dalla versione 0.6.0.3855 alla 0.6.0.3858 Home: -Link- Direct LinK: -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | INI Update: X-dvdisaster 0.71.23 [rev2] -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | INI Update: X-Hexplorer 2.6 [rev2] -Link- | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: JkDefrag 3.18 Win 2000/2003/XP/Vista Aggiornamento dalla versione 3.17 alla 3.18 Home: -Link- Direct Link: -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update INI: X-RatDVD 0.7.8 [rev3] -Link- Launcher only: 1188215625_1_FT9009_x-ratdvd_0.7.8_rev3_launcher.zip [ Edited Mon 27 Aug 2007 - 13:54 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: X-7Zip 4.53-beta Aggiornamento dalla versione 4.52-beta alla 4.53-beta Home: -Link- Direct Link: (not portable) -Link- [ Edited Mon 27 Aug 2007 - 19:47 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: JkDefrag 3.19 Win 2000/2003/XP/Vista Aggiornamento dalla versione 3.18 alla 3.19 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | MediaCoder 0.6.0.3865 Link winPenPack Aggiornamento dalla versione 0.6.0.3858 alla 0.6.0.3865 Home: -Link- Direct Link: -Link- [ Edited Tue 28 Aug 2007 - 22:31 ] | ||
