Aggiornamento: Rename Master Go to page >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Rename Master 2.7.5 Link winPenPack Aggiornamento dalla versione 2.7.4 alla 2.7.5 Home: -Link- Direct Link: -Link- [ Edited Thu 06 Sep 2007 - 15:54 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Rename Master 2.7.6 Link winPenPack Aggiornamento dalla versione 2.7.5 alla 2.7.6 Home: -Link- Direct Link: -Link- | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Rename Master 2.8.0 Aggiornamento dalla versione 2.7.6 alla 2.8.0 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Rename Master 2.8.1 Link winPenPack Aggiornamento dalla versione 2.8.0 alla 2.8.1 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Rename Master 2.8.2 Link winPenPack Aggiornamento dalla versione 2.8.1 alla 2.8.2 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Rename Master 2.9.0 Link winPenPack Aggiornamento dalla versione 2.8.2 alla 2.9.0 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Rename Master 2.9.1 Link winPenPack Aggiornamento dalla versione 2.9.0 alla 2.9.1 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare Note: La versione che viene scaricata riporta al suo interno ancora il numero 2.9.0 build 2202. controllo hash MD5 con la vecchia versione (2.9.0): rmv290.zip - 75ec4d85be5190448cb59ed94f9df176 rmv291.zip - 3d1870e4d1ae6dbe029e11a3cb29cf36 [ Edited Sat 25 Oct 2008 - 15:40 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Rename Master 2.9.2 Link winPenPack Aggiornamento dalla versione 2.9.1 alla 2.9.2 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare [ Edited Tue 03 Mar 2009 - 15:25 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Rename Master 2.9.3 Link winPenPack Aggiornamento dalla versione 2.9.2 alla 2.9.3 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Rename Master 2.9.4 Link winPenPack Aggiornamento dalla versione 2.9.3 alla 2.9.4 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare [ Edited Sat 23 Jan 2010 - 20:24 ] | ||
