Aggiornamento: X-WikidPad Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WikidPad 1.9 beta21 Link winPenPack Aggiornamento dalla versione 1.9 beta20 alla 1.9 beta21 Home: -Link- Direct Link: not portable -Link- ==EDIT zandet2== software wpp aggiornato [ Edited Fri 02 Jan 2009 - 17:52 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WikidPad 1.9 rc01 Link winPenPack Aggiornamento dalla versione 1.9 beta21 alla 1.9 rc01 Home: -Link- Direct Link: not portable -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Thu 12 Feb 2009 - 22:23 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WikidPad 1.9 rc02 Link winPenPack Aggiornamento dalla versione 1.9 rc01 alla 1.9 rc02 Home: -Link- Direct Link: (not portable) -Link- [ Edited Thu 09 Apr 2009 - 20:36 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WikidPad 1.9 rc03 Link winPenPack Aggiornamento dalla versione 1.9 rc02 alla 1.9 rc03 Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Thu 09 Apr 2009 - 20:50 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WikidPad 1.9 rc05 Link winPenPack Aggiornamento dalla versione 1.9 rc03 alla 1.9 rc05 Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Tue 16 Jun 2009 - 17:02 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WikidPad 1.9 rc06 Link winPenPack Aggiornamento dalla versione 1.9 rc05 alla 1.9 rc06 Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Mon 29 Jun 2009 - 11:53 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WikidPad 1.9 rc07 Link winPenPack Aggiornamento dalla versione 1.9 rc06 alla 1.9 rc07 Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Mon 03 Aug 2009 - 16:49 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WikidPad 1.9 rc08 Link winPenPack Aggiornamento dalla versione 1.9 rc067alla 1.9 rc08 Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Fri 28 Aug 2009 - 15:54 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Le icone incluse nelle versioni precedenti alla 2.0 non sono gratuite ma hanno una licenza commerciale. E' una conferma che ho avuto dall'autore del programma, al quale ho scritto dopo aver letto "free icon set to replace commercial ones" qui -Link- . Quindi direi di seguire direttamente gli sviluppi della versione completamente open source. X-WikidPad 2.0 beta 07 Link winPenPack Aggiornamento dalla versione 1.9 rc08alla 2.0 beta 07 Home: -Link- Direct Link: (not portable) -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WikidPad 2.0 beta 08 Link winPenPack Aggiornamento dalla versione 2.0 beta 07 alla 2.0 beta 07 Home: -Link- Direct Link: (not portable) -Link- [ Edited Sun 31 Jan 2010 - 23:15 ] | ||
