[moved] X-Openoffice 2.3 from English to German ?Vai a pagina >> |
| Peter G |
![]() ![]() Utente registrato #5718 Registrato il: mar 14 ago 2007 - 21:38Messaggi: 21 | Is there an easy way to convert the new X-Openoffice 2.3 in English (or Italian) to German ? | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12448 ![]() | Yes! Install this language pack -Link- to the X-OpenOffice\Bin\OpenOffice directory and open the X-OpenOffice.ini file replacing on line 31:
Line5=<value>it-IT</value>
Line8=<value>it-IT</value>
(I think) with:
Line5=<value>de-DE</value>
Line8=<value>de-DE</value>
[ Modificato mar 18 set 2007 - 15:43 ] | ||
| Taf |
![]() ![]() ![]() ![]() Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 2770 ![]() | Hi Peter G, Danix was faster than me! that's the right way [ Modificato mar 18 set 2007 - 15:35 ] | ||
| Peter G |
![]() ![]() Utente registrato #5718 Registrato il: mar 14 ago 2007 - 21:38Messaggi: 21 | Ehm ..... do I have to use the hole OOo2.3 in German or just the German Langpack ? --> your link refers to the hole OOo2.3 package ....... | ||
| Peter G |
![]() ![]() Utente registrato #5718 Registrato il: mar 14 ago 2007 - 21:38Messaggi: 21 | ok .... it's the languagepack I have to use ! I is realllllllllllllllyyyyyyyyyyyyyyyyyyyyyyyy !!!!! great !!!! Works fine ! Thanks ! | ||
| Taf |
![]() ![]() ![]() ![]() Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 2770 ![]() | You're Welcome! You are clever! In Danix's post there was a wrong link. now is correct to the languagepack ONLY Glad to be helpful.. Bye @DANIX: I changed the link in your post with the right one, sorry for my intrusion. scusami se ti ho corretto il link, puntava alla versione FULL e non al LANGPACK. [ Modificato mar 18 set 2007 - 15:44 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12448 ![]() | Sorry.. ![]() [ Modificato mar 18 set 2007 - 18:22 ] | ||
| Peter G |
![]() ![]() Utente registrato #5718 Registrato il: mar 14 ago 2007 - 21:38Messaggi: 21 | Well done ! Is there an alternative way to change language? -> Let's say, I have a regular installation of OOo 2.3 in German on my PC. --> Would it be possible to copy the installed directories and files (german version) to the X-Openoffice Package on my USB-stick, replacing the original files and directories (in Italian/English) there ? ---> the idea behind: I assume, the size of the X-Openoffice 2.3 package (in German only now) would be smaller than it is using the method with the additionally installed German Language pack....... I would like to have a "slim" X-Openoffice 2.3 package ..... ![]() | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12448 ![]() | Well, you have to delete all files present in \Bin\OpenOffice directory >> copy your german OOo (normal) installation directory to \Bin\OpenOffice >> and compress it using UPX Do you known UPX? -Link- ![]() [ Modificato mar 18 set 2007 - 22:20 ] | ||
| Peter G |
![]() ![]() Utente registrato #5718 Registrato il: mar 14 ago 2007 - 21:38Messaggi: 21 | The link to UPX goes to a dead page ("page not found") | ||
