[moved] X-Openoffice 2.3 from English to German ?
Peter G
mar 18 set 2007 - 12:19
Utente registrato #5718
Registrato il: mar 14 ago 2007 - 21:38
Is there an easy way to convert the new X-Openoffice 2.3 in English (or Italian) to German ?
mar 18 set 2007 - 12:27
Yes!
Install this language pack -Link- to the X-OpenOffice\Bin\OpenOffice directory and open the X-OpenOffice.ini file replacing on line 31:
Line5=<value>it-IT</value>
Line8=<value>it-IT</value>
(I think) with:
Line5=<value>de-DE</value>
Line8=<value>de-DE</value>
[ Modificato mar 18 set 2007 - 15:43 ]
mar 18 set 2007 - 12:36
Hi Peter G,
Danix was faster than me!
that's the right way
[ Modificato mar 18 set 2007 - 15:35 ]
Peter G
mar 18 set 2007 - 13:31
Ehm ..... do I have to use the hole OOo2.3 in German or just the German Langpack ?
--> your link refers to the hole OOo2.3 package .......
Peter G
mar 18 set 2007 - 13:48
ok .... it's the languagepack I have to use !
I is realllllllllllllllyyyyyyyyyyyyyyyyyyyyyyyy !!!!! great !!!!
Works fine !
Thanks !
You're Welcome!
You are clever! In Danix's post there was a wrong link.
now is correct to the languagepack ONLY
Glad to be helpful..
Bye
@DANIX:
I changed the link in your post with the right one, sorry for my intrusion.
scusami se ti ho corretto il link, puntava alla versione FULL e non al LANGPACK.
[ Modificato mar 18 set 2007 - 15:44 ]
mar 18 set 2007 - 18:21
Sorry..
[ Modificato mar 18 set 2007 - 18:22 ]
Peter G
mar 18 set 2007 - 21:56
Well done !
Is there an alternative way to change language?
-> Let's say, I have a regular installation of OOo 2.3 in German on my PC.
--> Would it be possible to copy the installed directories and files (german version) to the X-Openoffice Package on my USB-stick, replacing the original files and directories (in Italian/English) there ?
---> the idea behind: I assume, the size of the X-Openoffice 2.3 package (in German only now) would be smaller than it is using the method with the additionally installed German Language pack.......
I would like to have a "slim" X-Openoffice 2.3 package .....
mar 18 set 2007 - 22:19
Well, you have to delete all files present in \Bin\OpenOffice directory >> copy your german OOo (normal) installation directory to \Bin\OpenOffice >> and compress it using UPX
Do you known UPX? -Link-
[ Modificato mar 18 set 2007 - 22:20 ]
Peter G
mer 19 set 2007 - 08:00
The link to UPX goes to a dead page ("page not found")
