[WEB Utility] Ultimate Userbar |
icemax |
Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 | Nome Software:Ultimate Userbar Direct Link al download: -Link- Dimensione File: 1.18 MB (1245579) Nome autore: mariomeha eMail autore: nd Sito Web Autore: -Link- Descrizione: Ultimate Userbar consente di creare rapidamente una userbar da inserire come firma nei forum. Facilissimo da usare e totalmente portatile. Interfaccia abbstanza carina. Portable tips how-to: Il programma è totalmente portatile. [bisognerà decomrimere il file compresso] Versione:1.4.0 Licenza: freeware screenshot : Hi, I made an userbar creator a while ago.I decided to show it to the GMC. Many people like it. It's posted on many sites. That's a good thing. But well. Please, When you redistribute my project. Please put my name on your site. "Made by BrainWare aka Bryan Oostra" or whatever. Thanks Requirements: Windows XP due the xp icons. Sorry . They might look wierd in Windows 98 and 2000 or lower. It may work on others but then the icon is messed up (I think) V 1.4.0 - Can open/save .buf files - Set the default program for .buf files to UltimateUserbar.exe and it opens them - Png export - Best interface of all userbar makers - 19 different scanlines - 15 highlights - 8 outlines - Image input - Images with alpha masks - Text input - Randomizer - Alpha blended circles - Zoom function - Tooltips - Watermark (Corrupts your image for some image editors (photoshop)) - Outer glow - Multiple languages support! - Smaller PNG converter. But a dos windows pops up for 0.01 second. - 2 different gradient options. - Up to 8 sliders in your customizable gradient. - Premade templates - Premade sprites - More small things una info : in questo post -Link- un utente aveva suggerito di inserire la propria firma utilizzando appunto una user bar [ Modificato dom 30 set 2007 - 11:53 ] | ||
Moticanus |
Utente registrato #4618 Registrato il: gio 10 mag 2007 - 08:29Provenienza: Modica Messaggi: 1352 | Questo software purtroppo è ancora fermo alla v. 1.4.0 e non più presente sul sito dell'autore, anche se rintracciabile in rete. Posto il log di regshot solo perchè dalla segnalazione sono cambiate le linee guida! Spoiler: log_userbar.zip Dal punto di vista dell'applicazione è veramente di semplice utilizzo e ancora oggi attuale! [ Modificato dom 01 mar 2009 - 12:01 ] | ||
