X-Software running from a NON-writeable media ? |
| Peter G |
![]() ![]() Utente registrato #5718 Registrato il: mar 14 ago 2007 - 21:38Messaggi: 21 | Hi ! I have a - maybe very special (and maybe odd in some way) - question: Can X-Software be run from a NON-writeable media (like CD, locked USB-Stick). I would like to run X-Gimp 2.4.2 for demonstration use from a CD .... is that possible ? | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Just for a demonstration you can modify X-Gimp.ini and set the FileSystem. So, you can redirect the \User directory in the desktop (for example). Add this portion of code in your X-Gimp.ini :
[FileSystem]
[ Modificato dom 30 dic 2007 - 01:00 ] | ||
| Peter G |
![]() ![]() Utente registrato #5718 Registrato il: mar 14 ago 2007 - 21:38Messaggi: 21 | Good Morning ! I have tried that out. I have modified the gimp.ini like this: ---------------------------------------------------------------- [Setup] AppName=Gimp AppVer=2.4 [FileToRun] PathToExe=$Bin$\$AppName$\bin\gimp-$AppVer$.exe [FileSystem] Home=@DesktopDir@\User [Environment] ;------------------ ;Language (example) ;LANG=en ;------------------ ; User Directory GIMP2_DIRECTORY=$Home$\$AppName$ ;Thumbnails Directory HOME=$Temp$ ---------------------------------------------------------------- The "user" directory is created on the desktop. But that is still followed by an error-message in the setup ..... "The drive is non-writeable. Unlock the drive." (a "gimp-2.4.exe - writelockerror"). After clicking on "quit" or "go on" gimp is starting ...... ... well Gimp starts, but is there a solution without that annoying error-message ? Maybe the ini-file can be modified in that way, that no extra directories are written and no temp-files/directories are needed ? | ||
