PDF-XChange Viewer Portable 1.0031
deep
ven 04 gen 2008 - 17:24
Utente registrato #7
Nome Software: PDF-XChange Viewer Portable
Link diretto al download: -Link-
Dimensione file: 3,98 MB (4177905 Byte)
Autore: Tracker Software Products Ltd
E-mail autore: -eMail-
Sito Web autore: -Link-
Descrizione: Visualizzatore di file PDF versatile e potente.
Portable tips how-to: Estrarre il contenuto dell'archivio in una cartella a scelta. Avviare il programma da PDFXCview.exe.
Versione: 1.0031
Licenza: Freeware
P.S. Il link diretto si riferisce alla versione portatile (che non comprende i file HELP, comunque scaricabili a parte). Le informazioni sottostanti si riferiscono invece al programma in generale:
In addition to all the standard features here are some of the features available in the PDF-XChange FREE Viewer
* Add Comments and Annotations to any PDF file (subject to security settings) - unlike the Adobe Viewer which requires the PDF creation tool to be 'certified' by Adobe !
* Mark-up pages with text and objects
* Type directly on any PDF page, not just Adobe enabled forms documents - in Typewriter mode.
* Export PDF pages or entire files to any one of the supported Image formats including BMP, JPEG, TIFF, PNG and many more ...
* Extract text from a PDF page/File
* Make your navigation of large or complex PDF files both simple and enjoyable with the extended functionality of our 'Loupe' and the 'Pan' Window tools
* Fill and Save Adobe Forms to disk, email or 'post' !
* Full Javascript Engine included
* Updated JPEG2000 Compression support - improving speed.
* Plug-Ins for both MS IE or Firefox Browser's included
* Integrate seamlessly with your favourite translation software to translate text on the 'fly' - including : ABBYY Lingvo 12, Translate It!, Lingoes.
* Includes comprehensive Help file and PDF Manual - no extra downloads required to add features etc.
* Portable version also available - can be run from any suitable device such as a Memory stick/CD/DVD etc - simply unzip and use - no installation required !
And many more features such as Rotate and 'Save', Email files etc ...
Please ensure you 'Update' under the 'Help' drop down menu once installed and periodically thereafter to ensure you have the latest release.
[ Modificato ven 04 gen 2008 - 17:27 ]
dom 13 gen 2008 - 19:14
Utente registrato #5089
Per avere il programma anche in italiano:
Scaricare la versione install -Link-
Estrarre con universal extractor e prelevare il file PDFXVW_ITA.XML da copiare nella cartella Languages della versione portabile.
dom 13 gen 2008 - 19:17
La lingua italiana è inclusa anche nella versione .zip
dom 13 gen 2008 - 19:19
Il fatto è che stanotte quando l'ho testato so che c'era l'italiano.
Dopo aver letto ho riprovato il download ecc e non l'ho più trovato. Mi sono impanicata e ho creduto di aver sbagliato.
Sono contenta che tu lo confermi.
[ Modificato dom 13 gen 2008 - 19:19 ]
alchimista
dom 13 gen 2008 - 23:47
Utente registrato #3875
a me non c'è...
dom 13 gen 2008 - 23:55
Svelato l'arcano, hanno cambiato lo zip!
Ecco i dati relativi al pacchetto scaricato adesso e ieri dallo stesso link:
File: C:\Documents and Settings\Danix\Desktop\PDFX_Vwr_Port.zip
Modified: domenica 13 gennaio 2008, 4.17.33
MD5: 513B2318CB9896ED199DA8BC6A98888A
SHA1: 0C5C105A46F22494E9AFA69FE952BF98B9DC0A1E
CRC32: 96FA295D
File: C:\Documents and Settings\Danix\Desktop\Nuova cartella\PDFX_Vwr_Port.zip
Modified: domenica 13 gennaio 2008, 23.53.26
MD5: D4E49836169FA39D93AA533FB7D0E4B6
SHA1: A1459399347AD0699A8D86B20AAAF02C5A7ED70A
CRC32: D25F2EF9
lun 14 gen 2008 - 00:03
Madonna Danix, stavo impazzendo a capire quale fosse il problema. Va là
lun 14 gen 2008 - 00:15
Ciao ha tutti, io l'ho scaricato stamattina, ed vi è compresa la lingua italiana, ma selezionando la stessa (o altra), al successivo riavvio non la mantiene. Potrebbe essere questo problema che ha fatto cambiare il pacchetto.
------------ edit -------------
Effettivamente c'erano problemi con le traduzioni.
Ho riscaricato il nuovo .zip del programma (quello senza italiano) e mantiene le impostazioni della lingua, andandoci ha inserire la traduzione italiana presente nella versione di questa mattina , la medesima non viene mantenuta.
[ Modificato lun 14 gen 2008 - 02:00 ]
alchimista
lun 14 gen 2008 - 18:04
Riepiloghiamo... alle 18.00 nel file The PDF-XChange Viewer - Portable non è più presente la traduzione Italiana, ho scaricato l'exe, ho preso il file PDFXVW_ITA.xml, inserito nella cartella Languages, chiuso e riavviato il programma, tiene perfettamente la traduzione Italiana, speriamo non cambino ancora....
tDJ
mer 12 mar 2008 - 10:08
Utente registrato #9527
Registrato il: ven 07 mar 2008 - 17:36
PDF Xchange Viewer v2.0.0036
Update from version 2.0.0035 to version 2.0.0036
Home: -Link-
Direct Link: -Link-
