How to update ?? |
| TaZmaniak |
![]() ![]() Utente registrato #3206 Registrato il: mer 07 mar 2007 - 08:50Messaggi: 10 | Hi all, Beginner with WPP, i've download and install WPP 2.8 last week and see now there's a new WPP Launcher... Because i don't speak italian (i'm so sorry but i can assure you i love italian food ) i'd like to know how can i update my key with the new launcher without losing my configuration and all stuff i put in the launcher from the 2.8 ?Thanks a lot. | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 10496 ![]() | To update: - backup your winPenPack\User\winpenpack_launcher\winPenPack.xml file - overwrite winPenPack.exe - delete winPenPack\User\winpenpack_launcher\Lang folder - insert the new folder "Lang" in the same directory - insert the wppl.cur file in winPenPack\User\winpenpack_launcher\icons folder ![]() [ Modificato lun 12 mar 2007 - 13:14 ] winPenPack Links: Segnala software § Segnala aggiornamento § Segnala bug § Richiedi portabilizzazione § Regolamento § Aggiornamenti per wpp versione successiva § Collabora e contribuisci! Submit software § Submit update § Submit bug § Portable request § Forum rules § Updates for the next wpp version § Collaborate and contribute! | ||
| TaZmaniak |
![]() ![]() Utente registrato #3206 Registrato il: mer 07 mar 2007 - 08:50Messaggi: 10 | Thanks a lot. Saw you write it on the first page of the site also ![]() | ||
| Moderatori: Danix, Taf, Rcs, Energy, zandet2, ZioZione, Admin |
How to update ??
