KOffice |
JackL |
Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi, I know that it's in Beta still however probably you can find it interesting enough to portabilize it - it contains among others full office suite and graphic stuff - I even dare to claim it can replace openoffice + gimp and all in consistent look&feel - after all with Qt 4 undernith - it is available for 3 main platforms which make it prety handfull - you use one tool on every platform... only problem I see is that it can be too complex - but with new x-louncher2 - who knows? :] Cheers JackL | ||
Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3357 | Hi JackL, Yeah, IMHO is too early to consider Koffice as a possible substitute of OpenOffice. For windows at the moment i able to find only a Alpha10 release! In any case is better to wait for a more stable release. if someone wants to have a look... -Link- Anyway, many thanks for Your info. | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi JackL, Taf preceeded me for few minutes Please remember that it is always better to add a link regarding the signaled software... Thank you for your support! Best Regards ZioZione P.S. Taf, latest release is 2.0 beta1, that can be found here -Link- (there is a Windows Installer, it should work, but I don't have already tested...) [ Modificato ven 03 ott 2008 - 09:06 ] | ||
Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3357 | ZioZione ha scritto ... P.S. Taf, latest release is 2.0 beta1, that can be found here -Link- (there is a Windows Installer, it should work, but I don't have already tested...) sorry for my old link! Thanks Zio! | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Taf® ha scritto ... ZioZione ha scritto ... P.S. Taf, latest release is 2.0 beta1, that can be found here -Link- (there is a Windows Installer, it should work, but I don't have already tested...) sorry for my old link! Thanks Zio! Hi Taf, don't worry, maybe YOU are right... my link is taken directly from KOffice site, while yours is from KDe for Windows... Until test, I dont know what is the *REAL* latest one... Best Regards ZioZione | ||
JackL |
Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Yes - that is unclear a bit... but worth of observation though - I'm impressed by krita and some ofit's functionality (raw processing, 32bit color deth, artistic brushes/tools imitation algorythm....) If all suite is on this level of innovation - that would change the scores... cheers JackL | ||
