[Released] X-Unison 2.27.57_rev_1_test_1
pir
dom 24 gen 2010 - 10:49
Utente registrato #2110
Registrato il: gio 01 feb 2007 - 20:42
Provenienza: France
Please find hereafter the first test release version of X-Unison (Unison home page)
Second TEST Version (6.980.705 Byte/6,7 Mo)
http://zhutuzi.free.fr/files/X-Unison_2.27.57_rev_1_test_2.zip
Some Portalisation notes
- Unison preferences files are found according to UNISON environment variable (You can also use the HOME environment variable but I personally prefer to keep it pointing to my Documents folder).
- Unison preferences files are to be adapted to reflect the current winpenpack drive letter. I use for that a custom AutoIt udf that perform this task (you can find it in the src folder). I personally don't encourage you as using the existing FixDriveLetter directive from X-launcher 1.4 as it might break you preference file: X-launcher function does replace all drive letter so that it will certainly also alter other root directive in your preference files.
- Unison log file is created by default in the HOME directory. I have use the "-logfiles" directive to save it in the User\Unison folder to keep it separated from my Documents. This of course can be adapted to your personnal preference.
- Unison relies on GTK library. GTK library is refer to by adding to the PATH the GTK/bin location
I also perform a copy of GTK/etc content to User/gtk in order to keep the gtk configuration centralized and potentially share it with other GTK apps.
[Edited 2010.01.29]
Second test release according to Danix comments (see bellow)
[ Modificato sab 06 feb 2010 - 12:17 ]
dom 24 gen 2010 - 12:51
Hello pir,
I think it is better to change it to:
Parameters=-logfile "$Home$\$AppName$\unison.log"
Otherwise, in paths with spaces an error is shown:
I'd like to ask you about this part:
FixDriveLetter=%UNISON%\Portable_EDF.prf
FixDriveLetter=%UNISON%\Zhendows.prf
What are these files (Portable_EDF.prf and Zhendows.prf)?
- Unison relies on GTK library. GTK library is refer to by:
. adding to the PATH the GTK/bin location
. modifying GTK_EXE_PREFIX (and DATA_PREFIX) to GTK/ directory
I changed the GTK code with:
; GTK library location
PATH=$Lib$\GTK\bin
To install a gtk configuration, is not enough to copy the preconfigured files only once?
For example:
;Install GTK configuration files
DirCopy=$Lib$\$AppName$_gtk|$Lib$\GTK\etc|o
DirRemove=$Lib$\$AppName$_gtk
pir
dom 24 gen 2010 - 13:23
Provenienza: France
Hello Danix,
Thanks for your quick feedback
I update it in the next test relaese
These two files are unison preference files that I use. These files contain directive to tell unison what to synchronize, therefore they usually contain reference to the USB drive letter from which X-Unison is launched. They defintly need to go through FixDriveLetter to be used.
I include them in the ini only for example to show how to fix the drive letter. This INI part shall be adapted to your use to fit your config.
Possibly, it would be better to comment out this part in the default ini ?
An alternative could be to run FixDriveLetter to $Home$\$AppName$\*.prf but at the moment the use of wildcards is not supported by x-udf.au3.
PATH=$Lib$\GTK\bin
OK. No problem for me. Just to understand, why not keep %PATH%;$Lib$\GTK\bin and GTK_EXE_PREFIX ?
For example:
Yes, you're rigth. The RunAfter entry is of no use.
dom 24 gen 2010 - 14:09
Not sure I understand, but the new "_WriteWinPenPackDriveLetterToFile()" and "_NeutralizeWinPenPackDriveLetterInFile()" functions fix all paths of recent folders?
Or they change only the drive letter? Maybe can be usefull if you could post these files (deleting your eventual personal data, for privacy).
Why keep them if not necessary?
At least, for what I've noticed..
pir
lun 25 gen 2010 - 11:05
Provenienza: France
A typical unison preference file is like this one:
label=prf_comp1
root = C:\my_data
root = D:\my_data_on_my_usb_stick
path = dir_1
ignore = Path dir_1/cache
Then it is required to change D: to the actual USB drive letter but leaving C: untouched.
The second difficulty is that I have another preference files to synchronize my USB stick to another computer whose config looks likes this:
label=prf_comp2
root = D:\my_data
root = E:\my_data_on_my_usb_stick
Then if I "fix" the drive letter on the first computer, I break my second profile :
label=prf_comp2
root = D:\my_data
For that reason my idea is to adapt my config files to :
label=prf_comp1
root = C:\my_data
root = %WPPDriveLetter%:\my_data_on_my_usb_stick
and
label=prf_comp2
root = D:\my_data
- Let say that the current USB drive is D: in my first computer
- before running the application, _WriteWinPenPackDriveLetterToFile() adapt the files by replacing %WPPDriveLetter% by the actual USB driveletter and in case it finds an occurence in the file that is the USB drive letter (here D:) it preserves it for later use (by puting it between %..%). In my examples, the first file is transformed to :
label=prf_comp1
root = C:\my_data
and the second one to
label=prf_comp2
root = %D%:\my_data
With this approach, the first file is operational, and on the second I preserved the "D:" root which should be left untouched.
- after X-Unison is closed they are put back to their original form by _NeutralizeWinPenPackDriveLetterInFile()
Hope that I'm clear
Done. Upload test 2 as soon as possible. thanks !
mar 26 gen 2010 - 01:44
pir ha scritto ...
Hope that I'm clear
Almost.
But, have you considered that, after this performance (and also this one), you could be included immediately in our development Team?
mar 26 gen 2010 - 08:53
@pir
Hi pir, you made a great job!
not only quoting Danix...
...would be very grateful and helpful if You decide to became a winPenPack member.
IMHO, You will be really welcome!!
pir
ven 29 gen 2010 - 09:50
Provenienza: France
@Danix and @Taf
Thanks so much for your appraisal
I, of course, be very pleased to help you further.
Is there something special to be done ?
sab 30 gen 2010 - 11:51
pir ha scritto ...
@Danix and @Taf
Hi pir,
nothing different from what you have alreary done: excellent portabilizations...
We would very proud to welcome you in the Team...
Best Regards
sab 17 nov 2012 - 17:30
Released X-Unison 2.40.16 [rev2]
