Impossibility to change the language permanently in X-KeePass-1 1.21 rev[10] |
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 153 | I've tried to change in the X-KeePass-1 1.21 rev [10] the language from English to German. To this end I started X-KeePass and went to View -> Change Language ... German and selected the language German. Then it worked flawlessly. But when I finished the program X-KeePass and I started it again, the English language was set. How can I solve this language problem? | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3819 ![]() | Hi dropper, I suppose that you are using the \English_users\X-KeePass-1.ini file, copied into the root folder, and also that you already downloaded the german.lng file fromm KeePass site and copying into \Bin\KeePass-1 folder (sorry for being so pedantic, is not for you, but to give a general method to all other users). The .ini file is localized in English and uses the KeeLanguage=Standard option. For let it work in German language, you have substantially two ways, both editing X-KeePass-1.ini file: 1) (preferred) comment row 45, i.e. prefix it with a ";" character, as follows
;KeePass|KeeLanguage=Standard
2) edit row 45 as follows
KeePass|KeeLanguage=German
The option (1) is preferred (by me ) because is more general and allows also other languages users to let X-KeePass-1 to be localized in their native language.Of course, changing the language from within KeePass, it asks to restart. DON'T RESTART, but close and rerun X-KeePass-1.exe. Please let me know if this fixes your problem. Best Regards ZioZione | ||
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 153 | Hi ZioZione, The solution, which you have described, is applied to the case, that I downloaded X-KeePass 1_1.21_rev10.zip and then extracted it into a self-selected folder (eg the folder named "X-KeePass"). In my case I use X-KeePass about the winPenPackNet_Full menu. Also I have downloaded from the website -Link- the current version of the file "German.lng". Then I have pasted this file "German.lng" in the folder D:\wpp_full_4.0-beta2\winPenPack\Bin\KeePass-1 (overwriting the existing file "German.lng"). Therefore, I would recommend that in the official version of X-KeePass-1 1.21 rev[10] already this current file "German.lng" is included.Then I went into the folder D:\wpp_full_4.0-beta2\winPenPack\XDrive\en and copied the file "X-KeePass-1.ini" and pasted it into the folder D:\wpp_full_4.0-beta2\winPenPack\XDrive (overwriting the existing file "X-KeePass-1.ini"). Then I edited the file "X-KeePass 1.ini" according to your proposed variant 1. ZioZione wrote ... 1) (preferred) comment row 45, i.e. prefix it with a ";" character, as follows ;KeePass|KeeLanguage=Standard Now I've started X-KeePass and changed the language from within X-KeePass. It asks to restart and when I do it, X-KeePass started properly in German. [ Modificato mar 18 ott 2011 - 11:54 ] | ||
