Setting up X-Firefox 8.0 [rev4] as default browser is impossible
dropper
dom 13 nov 2011 - 13:25
Utente registrato #39636
Registrato il: mar 15 feb 2011 - 23:47
About red Firefox button top left -> Options -> Options I opened the new window called "Options". Now I chose the tab called "Advanced" and within that the tab called "General". Within the section "System Defaults" I activated the checkbox called "Always check to see if Firefox is the default browser on startup". Afterwards I clicked on the button called "Check Now". Unfortunately I can't set up Firefox as default browser by this measure.
What is the reason for this problem? Can it be, that is violated the portability by this setting as the default browser?
dom 13 nov 2011 - 21:20
Hi dropper,
the short answer is: yes.
Suppose you have X-Firefox installed on a pendrive. Setting X-Firefox as default browser, you must perform some actions that register such information into the registry and, more generally, into the guest PC (independently from the portabilization of X-Firefox). Then, removing the pendrive, you leave the system in an inconsistent state... Not exactly the definition of "portable"...
Fortunately, there is a solution, and it comes from winPenPack...
Install X-Firefox into winPenPackNet menu, open the X-Firefox properties, click on the Protocols tab, check the "Http/Https" checkbox, press OK button.
From this moment on, until the winPenPackNet menu is active (i.e. running), whenever you click an http/https link, X-Firefox is executed, as it were the default browser. When you close winPenPackNet, the default browser of the guest PC returns back to its original value.
The only drawback (if you want to call it so) is that you must execute winPenPackNet for having X-Firefox the default browser... But you have so much advantages that I think this little fact is absolutely secondary...
Hope this helps!
Best Regards
dropper
dom 13 nov 2011 - 22:49
Hi ZioZione,
Meanwhile I've found, that are generated some entries in the following registry keys, when I set Firefox as default browser.
  • HKCR\.htm
  • HKCR\.html
  • HKCR\FirefoxHTML\shell\open\commend
All these registry keys remain after closing Firefox.
ZioZione wrote ...
Accordingly, I am very impressed from the variant described here. Thanks for this surely hard work of programming
[ Modificato dom 13 nov 2011 - 22:50 ]
lun 14 nov 2011 - 07:42
dropper ha scritto ...
SNIPPED POST
ZioZione wrote ...
Hi Dropper,
moreover, using ZioZione's suggestion, You can have same possibility to set X-thunderbird as a "temporary" default mail user agent. clicking on "MailTo" option and, if needed, also for your preferred FTP program (x-filezilla maybe? )
Anyway, if you don't want to use winPenPack menu and you don't care registry settings, you can use 2 small programs to set x-firefox as "difinitively default browsers".
on win XP -> "DefaultBrowser" -Link-
on Vista/Seven -> "RegisterFirefoxPortable" -Link-
but, in my humbly opinion, in this case I would suggest to run a plain installation of Firefox as the best solution. In fact, using a portable edition like the normal one is a "nonsense" way of working.
[ Modificato lun 14 nov 2011 - 07:56 ]
dropper
lun 14 nov 2011 - 21:15
Hi Taf,
It is indeed true that I use both X-Thunderbird and X-FileZilla. That's why I think, that your advice, both programs to temporarily use as the default programs, is very useful. But more and more I am increasingly fascinated by the many possibilities of settings in the winPenPackNet menu
Of course you are right,that the locally installed version of Firefox offers more features than the portable version.
Personally I weigh out, how important are some features of a program for me. And if I want to use them, then of course I install the appropriate program locally.
