X-Firefox 8.0.1 [rev4] not jump list(task) on windows 7. thanks. |
dlusera |
Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | Recent, update to windows 7 sp1, then try X-Firefox 8.0.1 [rev4] and pinup the X-firefox, but not show jump list(task) on windows 7. I try install version firefox 8.01, that ok, has a jump list(task). I test other portable software such as ccleaner , opera usb portable all support jump list(task) on windows 7. I hope X-firefox can fix this bugs. also, other support jump list software too, I think all X-sofftware can't support jump list. Hope fix and update. thanks. many user need jump list on portable. sorry, my bad english. | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi dlusera, I don't know if I correctly understand your problem, but I use daily X-Firefox 8.0 and it supports without problems jump lists, as you can see in the attached picture. Can you explain in more details what you do and what you get (i.e. some screenshot)? Best Regards ZioZione | ||
dlusera |
Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | I test 8.0 is ok. but 8.0.1 can't , are you test this version ? thanks. My screen here: -Link- [ Modificato mer 07 dic 2011 - 13:21 ] | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi dlusera, I tested X-FF 8.0.1 in a separate folder from 8.0 (i.e. I don't updated 8.0 to 8.0.1, but tested from scratch 8.0.1, as, I think, you have done). 8.0 manages very well the jump list, while, at first sight, 8.0.1 don't. But, after some testing (and runs), I noted that also for X-FF 8.0.1 the jump list is populated and visible. So, I think that you need some time to populate the jump list cache, but it should finally work as expected. Hope this helps. Best Regards ZioZione | ||
dlusera |
Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | OK. I try first. thanks support. | ||
dlusera |
Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | Thanks ok, now. need re-start 3 time. | ||
