Language switching impossible in the GUI of LibreOffice 3.4.6 [rev7] |
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 153 | At the first start of LibreOffice 3.4.6 [rev7] I changed the language to Germany (for both the GUI and the dictionary). However, the GUI of LibreOffice continues to appear in english language. What must I do to change the language? [ Modificato ven 23 mar 2012 - 09:58 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12452 ![]() | You have made a first installation or an update? I just tested a fresh install and it works after selecting the german language. | ||
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 153 | Unfortunately I have done a downgrade from my installed newer version LibreOffice 3.5.1 [rev9] to the older version LibreOffice 3.4.6 [rev7]. Probably this was the reason for the language problem. Now I have done an upgrade from the older version to the newer version. And it's all ok. | ||
