Language switching impossible in the GUI of LibreOffice 3.4.6 [rev7]
dropper
ven 23 mar 2012 - 09:57
Utente registrato #39636
Registrato il: mar 15 feb 2011 - 23:47
At the first start of LibreOffice 3.4.6 [rev7] I changed the language to Germany (for both the GUI and the dictionary). However, the GUI of LibreOffice continues to appear in english language. What must I do to change the language?
[ Modificato ven 23 mar 2012 - 09:58 ]
ven 23 mar 2012 - 12:44
You have made a first installation or an update?
I just tested a fresh install and it works after selecting the german language.
dropper
ven 23 mar 2012 - 16:48
Unfortunately I have done a downgrade from my installed newer version LibreOffice 3.5.1 [rev9] to the older version LibreOffice 3.4.6 [rev7]. Probably this was the reason for the language problem. Now I have done an upgrade from the older version to the newer version. And it's all ok.
