[moved] why X-firefox 3.6.28 not update ? thanks. |
dlusera |
Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | before has a update, following the x-firefox 10.X. so, not already stop update and support for firefox 3.6XX ? before, my computer slow, need used old version, hope can continue. thanks. | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi dlusera, are you talking about this -Link- ? You can upgrade X-Firefox also from itself (menu Help|About) pressing the button "Check upgrades" (or similar, sorry, I have Italian version...). When Firefox downloads and installs the upgrade DON'T RESTART, but simply close and rerun X-Firefox. Hope this helps Best Regards ZioZione | ||
dlusera |
Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | That, I already update. but the portable java new version 6U31 not working. I manual use the java 6U30, is OK. I think that a x-firefoz 3.6X Bugs. I also test the 6U31 with X-firefox 11.0 Rev5, that working. hope fix the java problems on X-firefox 3.6X. thanks. | ||
