Meaning of the settings in the file xnview.ini
dropper
mar 05 giu 2012 - 20:27
Utente registrato #39636
Registrato il: mar 15 feb 2011 - 23:47
On the download page XnView is described the necessity of creation of a xnview.ini file in the program folder before the first run of xnview.exe. The xnview.ini file should contain the following settings:
[Cache]
SavingMode=1
[Start]
ParamsSavingMode=1
SavingMode=1
Can someone explain me the meaning of these settings?
gio 07 giu 2012 - 14:40
Hi dropper
dropper ha scritto ...
[Cache]
SavingMode=1
[Start]
ParamsSavingMode=1
SavingMode=1
SavingMode=1 (both into [Cache] and [Start] section) should disable the cache. This should improve performances when running XnView from USB pendrive.
ParamsSavingMode=1 means that XNView saves its settings into XnView folder (versus ParamsSavingMode=0, that saves into user folder, and ParamsSavingMode=2, that saves into Windows folder).
All these settings are necessary for allowing XnView to run in a portable manner.
If you need additional informations, please refer to XnView forum, as we have done.
Hope this helps!
Best Regards
dropper
gio 07 giu 2012 - 15:12
As always many thanks for the thorough answers and the remarks on the use of the XnView forum.
At this point I want not forget to mention, that I also participate in other forums. But the quality of the winPenPack forum is with clear distance the highest
gio 07 giu 2012 - 20:46
Hi dropper,
we do all the best for give always exhaustive answers, and we are happy when this objective is reached...
Thank you very much! As always, you are welcome!
Best Regards
