Extraction of the file picpick_inst.exe doesn't work
dropper
lun 10 set 2012 - 15:28
Utente registrato #39636
Registrato il: mar 15 feb 2011 - 23:47
I tried to extract the file picpick_inst.exe (regarding the new version 3.1.8) with X-UniExtract 1.6.1 [rev4]. Unfortunately without any success. The extracted file picpick.exe is damaged. In contrast, extracting work fine with X- 7zip.
Has anyone an idea, why the extraction doesn't work with X-UniExtract 1.6.1 [rev4]?
mar 11 set 2012 - 14:26
dropper ha scritto ...
Hi dropper,
the extracion of PicPick fail because X-UniExtract is bundled with an old version of 7zip extractor (9.13); that's why if you use X-7Zip directly, that is updated at 9.22 version, the extraction is successfull.
dropper
mar 11 set 2012 - 14:43
Thanks for your explanation. Is it therefore sufficient, if I replace the old file 7z.exe (version 9.13) with the latest file 7z.exe (version 9.22) within the folder winpenpack\Bin\Uniextract\bin. But I found in this folder another file 7z.dll. Must I also replace this file?
mar 11 set 2012 - 15:11
Yes, you have to replace both.
Anyhow, I'm planning to pack a new version of X-UniExtract updating the outdated softwares, not only 7zip but also upx, lzop and so on.
