[winPenPack Net Menu] Swedish translation
Vai a pagina   <<
eson
sab 10 nov 2012 - 12:49
Utente registrato #40310
Registrato il: mer 21 mar 2012 - 09:23
P.S. Please note that there is only the translation of the list ("winpenpack_sv.xml") and not the "winPenPack.sv.ini" file.
Hi Danix!
May I ask why you did not add my "winPenPack.sv.ini" file? Is there something wrong with it?
Works just fine on my machine.
//eson
[ Modificato sab 10 nov 2012 - 12:51 ]
sab 10 nov 2012 - 13:13
I'm sorry, eson, but I had not seen! I will update the package as soon as possible.
In the meantime can you check that all strings are translated? I think in new files there is some change.
-- edit --
Diff to previous -Link-
[ Modificato sab 10 nov 2012 - 13:21 ]
eson
sab 10 nov 2012 - 15:08
Ok... I found the one new string. Here´s the updated files attached.
sv_winpenpacknetmenu_2867.zip
[ Modificato sab 10 nov 2012 - 15:12 ]
sab 10 nov 2012 - 19:54
I have updated the package -Link-
Thank you for the translation! -Link-
Vai a pagina   <<
