[Released] X-Calibre 0.9.18_rev1
dom 18 gen 2009 - 00:46
Nome del software: Calibre
Dimensione File: 25.060.966 (23,9MB) (file .exe)
Nome autore: kovidgoyal
eMail autore:
Lingua: multilingua (italiano compreso)
Descrizione: Software di gestione biblioteca con interfaccia pulita, ma con numerose funzioni. Possiede anche un convertitore di formati e un lettore ebook multiformato.
Portable tips how-to: L'estrazione con UE non è supportata. Va installato e disinstallato. Per i test vi fornisco della mia copia install/disinstall
Versione: Version: 0.4.128
Licenza: GPL
Info originali:
calibre is a e-book library management application. It is free, open source and cross-platform in design and works on Linux, OSX and Windows. calibre is meant to be a complete e-library solution and thus includes, library management, format conversion, news feeds to ebook conversion as well as e-book reader sync features. A full description ofFeatures as well as some Screenshots. calibre is written purely in python.
Nota1: allego log di regshot. Lascia paaaarecchie tracce log_calibre.zip
Nota2: il lettore e-book è separato dal software principale, quindi avviabile singolarmente.
[ Modificato lun 11 feb 2013 - 17:41 ]
mar 10 mar 2009 - 22:14
Versione: 0.5.0 (9.3.09)
Changelog:
* Fix #2003 (lrs2lrf mistranslates XML entities)
* Fix #2005 (Updated recipe for NIN online)
* Implement #1996 (Trimming option in cbr conversion)
* Fix #2004 (PDF to EPUB conversions not working)
* Fix bug causing laguage to be set to Arabic in OS X when the config dialog is run
* Fix #2017 (Another PRC file cover detection issue)
* Fix #2012 (epub output problems on PRS505)
* New recipe for Eco Geek? by Darko Miletic
* Fix #2018 ([ERROR] CSSValue: Missing token for production Choice)
* Fix #2000 (Error on importing PDFs, CBZs and LRFs into Calibre)
* New recipe for Miami Herald by Darko Miletic
* Fix #1917 (Calibre will not close when clicking any exit button)
* New recipe for Mediapart.fr by Mathieu Godlewski
* New recipe for Wikinews by Darko Miletic
* Remove dependency on help2man. Also significantly speds up man page generation
* Fix the Opinion section of the no subscription NYTimes recipe
Test effettuato: Utilizzando il contenuto della cartella di installazione il software è avviabile
Note sulla portabilità: continua a lasciare parecchie tracce -> log_calibre.zip
_zulu
mar 28 giu 2011 - 18:15
Utente registrato #3957
Registrato il: lun 09 apr 2007 - 01:39
Vi segnalo che l'autore di questo software ha realizzato una versione portabile (attualmente la 0.8.7).
Non ho effettuato dei test, ma sicuramente ora il software merita un nuovo controllo.
Bourne
sab 23 giu 2012 - 07:02
Utente registrato #4287
_zulu ha scritto ...
Purtroppo la loro versione portabile non è tale, rimane la solita chiave TrollTech.
lun 21 gen 2013 - 00:15
Test richiesto/Test needed:
X-Calibre_0.9.15_rev1_test1
--- edit ---
Rilasciato/released:
X-Calibre_0.9.18_rev1
[ Modificato lun 11 feb 2013 - 17:44 ]
lun 21 gen 2013 - 12:13
O.S. windows 7 Pro 64bit
TUTTO OK! (nessuna chiave trolltech residua)
duwil
lun 21 gen 2013 - 18:52
Utente registrato #6659
Registrato il: mar 23 ott 2007 - 18:34
Ho fatto un test di funzionalità e ho notato che impostando come default una libreria preesitente, al successivo riavvio viene reimpostata la libreria in C:\Users\nome_utente\Calibre Library".
Premesso che le mie conoscenze sono limitate, se volessi usare come cartella di default per i libri una cartella su un percorso assoluto, sarebbe giusto e sufficiente ad es. modificare X-Calibre.ini così?
;Parameters=--with-library "%CALIBRE_LIBRARY_DIRECTORY%"
Parameters=--with-library "K:\var\libreria"
[ Modificato lun 21 gen 2013 - 18:54 ]
lun 21 gen 2013 - 19:21
duwil ha scritto ...
E' una cosa voluta proprio per conservare il percorso alla libreria anche in caso di spostamento del programma da un percorso (o da un drive) all'altro.
E' preferibile modificare il percorso della libreria nella variabile %CALIBRE_LIBRARY_DIRECTORY% sotto [Environment], così:
[Environment]
CALIBRE_LIBRARY_DIRECTORY=K:\var\libreria
duwil
mar 22 gen 2013 - 14:46
Grazie Danix, lo sapevo che non avevo guardato con abbastanza attenzione!
Comunque credo di aver fatto qualcosa di "strano" nel wizard del primo avvio oppure ho fatto confusione non controllando adeguatamente cosa succedeva nelle cartelle "giuste". Eliminando le cartelle e i file di x-calibre e reinstallandolo il problema non si è ripresentato: ora la libreria viene impostata invece che su "C:\Users\nome_utente\Calibre Library" nella cartella "Documents\Calibre Library" all'interno della struttura di wpp e quindi così mi va bene. La prossima volta prima di scrivere farò una doppia prova...
ven 25 gen 2013 - 15:21
Nuova versione:
X-Calibre_0.9.16_rev1_test2
Attenzione: il percorso della libreria (Calibre Library) non deve essere più lungo di 75 caratteri, altrimenti appare un errore e viene creata un'altra libreria in %AppData%\Utente\Calibre Library:
Siccome in X-Calibre il percorso della Libreria è preimpostato su \Documents\Calibre Library, per evitare questo inconveniente bisognerà posizionare il programma su un percorso breve (ad es.: H:\winPenPack) anzichè su un percorso troppo lungo (ad es.: C:\Documents and Settings\Utente\Desktop\X-Calibre_0.9.16_rev1).
New version:
Warning: the library path (Calibre Library) must have maximum 75 characters, otherwise an error will appear and another library will be created in %AppData%\User\Calibre Library:
Since in X-Calibre the library path is set to \Documents\Calibre Library, to avoid this issue, it is mandatory to place the program into a short path (eg.: H:\winPenPack) instead of a longer one (eg.: C:\Documents and Settings\User\Desktop\X-Calibre_0.9.16_rev1).
[ Modificato lun 11 feb 2013 - 17:45 ]
