annoying dialog window at every start of X-Thunderbird |
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | At every start of X-Thunderbird a dialog window named "System Integration" will opened. In this window will me offered the option, that I can choose Thunderbird as the default email program on my PC. Accordingly must I click on the button "Cancel" everytime. That's not really convinient I use the OS Windows 8. [ Modificato mer 17 lug 2013 - 23:01 ] | ||
Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3357 | As usual (I hope),x-thunderbird.ini file can be your friend! have a look if under [USER PREFERENCES] you have this line: ; Default Client mail.shell.checkDefaultClient=false if you already have this option (not commented), maybe we need to test X-thunderbird on Win8 system. | ||
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | In the file X-Thunderbird.ini under [USER PREFERENCES] I found exactly the line, which you've mentioned in your comment. Accordingly is there an issue with the OS Windows 8. | ||
Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3357 | OK, now the biggest problem is to find out a Windows 8 PC in our staff! | ||
