Aggiornamento: RJ TextEd
Vai a pagina   <<        >>
gio 25 mag 2017 - 00:01
RJ TextEd 12.10
Link winPenPack
Aggiornamento dalla versione 12.06 alla 12.10
Home: -Link-
Direct link portable: -Link-
dom 23 lug 2017 - 02:24
RJ TextEd 12.20
Link winPenPack
Aggiornamento dalla versione 12.10 alla 12.20
Home: -Link-
sab 02 set 2017 - 15:20
RJ TextEd 12.30
Link winPenPack
Aggiornamento dalla versione 12.20 alla 12.30
Home: -Link-
rbon
lun 04 set 2017 - 13:32
Utente registrato #4134
RJ TextEd 12.31
Link winPenPack
Aggiornamento dalla versione 12.30 alla 12.31
Home: -Link-
Nota
Il file portable ha la rel. 12.30 e quindi è necessario scaricare il file di aggiornamento alla ver 12.31:
- Update files (v12.31) - install: -Link-
- Update files (v12.31) - archive: -Link-
What's New:
(from Forum -Link- )
New in this version:
Version 12.31 (Sep 3, 2017)
Fixed
* Font issue in search result panel.
* Editor undo issue.
* FTP tree issue.
* File explorer issue.
* File Commander issues.
* A few split window issues.
* Several FTP issues.
* Several reported exceptions (error messages).
This version is available. Install using the auto update feature or download (archive) from -Link-
[ Modificato lun 13 set 2021 - 20:46 ]
rbon
mer 24 feb 2021 - 19:26
RJ TextEd 14.72
Link winPenPack -Link-
Aggiornamento dalla versione 12.30 alla 14.72
Home: -Link-
Download page: -Link-
FossHub repository for RJ TextEd: -Link-
Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 14.70: -Link-
Signature for 'TextEd 32-bit + 64-bit Windows Portable':
• MD5        281a63a55578295e271f1289f4e4eee8
• SHA1       6cf0f0208e48cfa7e2eb387747d6f926e4eb0393
• SHA256     b14a97177e74e46b87ca75cac5f71d0023bcf21bac2c96bc68539b65d4cf1a60
'TextEd 32-bit + 64-bit Windows Portable' size: 157 MB
Nota
Il file portable ha la rel. 14.70 e quindi è necessario scaricare il file di aggiornamento alla ver. 14.72:
- Update files (v14.72) Portable: -Link-
What's New:
Version 14.72 (February 17, 2021)
Misc
* Arabic was added to the list of available languages.
* Cpp syntax file was updated.
Fixed
* SFTP issues when changing remote directory.
* Lorem Ipsum in HTML menu could not be translated.
* Exit compare mode error.
* Change case functions in multi selection mode.
* A startup issue where some file may not be accessible.
* Minor issues in the Regular expression Creator.
* Dual view action issue.
* Error in customize keyboard shortcut window.
* Redraw issue when a panel is hidden to a side.
* Current file path in explorer panel toolbar should work now.
* Delete issue when external document is visible (tab dragged outside the document area).
* Save All enable issue when using multiple document views.
* Close bracket issue in style section.
By The Way
L'autore di RJ TextEd (Rickard Johansson) si deve essere accorto che il suo editor ha raggiunto una dimensione 'monstre' e sta lavorando ad una versione Lite, cioè molto più leggera.
• RJ TextEd Forum: -Link-
• MPad (RJ Texted Lite): -Link-
-> in questa discussione l'autore sta cercando un nome appropriato per la nuova versione Lite.
rbon
dom 18 lug 2021 - 19:20
RJ TextEd 15.00
Aggiornamento dalla versione 14.72 alla 15.00
Home: -Link-
Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.00: -Link-
Local help file (2021-07-10): -Link-
Nota
La versione corrente è tuttavia la 15.0.3 rilasciata il 16 luglio 2021, ma non è ancora stata caricata su FossHub.
RJ-TextEd versione corrente:
La versione corrente 15.00 (15.0.3) è per Windows 7, 8.1, 10.
Windows XP/Vista/Linux(Wine) (version 15.0.3):
Questa versione è stata compilata con una vecchia versione di Delphi.
-> download portable: -Link-
gio 09 set 2021 - 12:06
Utente registrato #9
Provenienza: Veglie
RJ TextEd 15.10
Aggiornamento dalla versione 15.00 alla 15.10
Home: -Link-
Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.10: -Link-
Local help file (2021-08-28): -Link-
Nota
La versione corrente 15.10 è per Windows 7, 8.1, 10.
Windows XP/Vista/Linux(Wine) (version 15.10):
[ Modificato gio 09 set 2021 - 12:07 ]
mar 05 ott 2021 - 21:06
Provenienza: Veglie
RJ TextEd 15.20
Aggiornamento dalla versione 15.10 alla 15.20
Home: -Link-
Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.20: -Link-
Local help file (2021-10-04): -Link-
Nota
La versione corrente 15.20 è per Windows 7, 8.1, 10.
Windows XP/Vista/Linux(Wine) (version 15.20):
[ Modificato mar 05 ott 2021 - 21:07 ]
gio 21 ott 2021 - 00:57
Provenienza: Veglie
RJ TextEd 15.22
Aggiornamento dalla versione 15.20 alla 15.22
Home: -Link-
Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.22: -Link-
Update file: Installer Portable (15.22)
Nota
La versione corrente 15.22 è per Windows 7, 8.1, 10.
[ Modificato gio 21 ott 2021 - 16:27 ]
mar 09 nov 2021 - 08:30
Provenienza: Veglie
RJ TextEd 15.23
Aggiornamento dalla versione 15.22 alla 15.23
Home: -Link-
Direct download 'TextEd 32-bit + 64-bit Windows Portable' ver 15.23: -Link-
Update file: Installer Portable (15.23)
Local help file (2021-11-08): -Link-
Nota
La versione corrente 15.23 è per Windows 7, 8.1, 10.
[ Modificato mar 09 nov 2021 - 08:30 ]
Vai a pagina   <<        >>
