Virtual machine
valentino.b
lun 02 mag 2022 - 13:28
Utente registrato #41787
Registrato il: gio 10 lug 2014 - 14:23
Hi all
exists a "portable tool" that allow us to create and run Virtual machines?
I read that VirtualBox isn't usable
Thank you
lun 02 mag 2022 - 16:37
Utente registrato #9
Provenienza: Veglie
valentino.b ha scritto ...
Hi all
Thank you
Many years ago I used to translate this software, MobaliveCD.
Is not portable, but it's a stand-alone program that works as a virtual machine for Live-CD. With this program you can test a live OS before a final installation (usually Linux OS live CD).
In any case, I'll try to find a more suitable program for you.
valentino.b
sab 28 mag 2022 - 08:58
I found GreenVBOX (http://greenvbox.org/) that can execute v.6.1.34 (lastest) of VirtuaBox without installation.
It seems a freeware that can execute VirtuaBox like a portable.
It could become a product of WinPenPack?
sab 28 mag 2022 - 10:11
Provenienza: Veglie
I don't think so, because they prefer to include only opensource programs.
Test it with Regshot.
Obviously you have to take a shot before installing GreenVBOX and another one after the program installation.
Maybe the staff can consider it despite the freeware license.
[ Modificato sab 28 mag 2022 - 13:15 ]
Blackcrack
dom 29 mag 2022 - 13:26
Utente registrato #41707
Registrato il: sab 28 dic 2013 - 08:45
qemu, is portable, download the zip-package for you're Architecture (x86 or x86_64)
https://www.qemu.org/download/#windows
i see only setupfiles ? bahh.. extract the setup in a folder, include subfolders, go in and start qemu with "/?" switch
and read the Manual/Documentary/instructions..
you can guide the qemu with bachfiles or directly with switches... (qemu.exe --bla --bla --bla"
qemu was in the past a linux-binary in a rpm and be made later as a windows-binarys too..
therewith know i am , to be normally in native, portable, without a "Copy and link programm (so a setup programm)"
because this, can you unpack qemu and put it into a folder&usb-stick and should run..
best
Blacky
[ Modificato lun 30 mag 2022 - 11:23 ]
