[motori di ricerca] Google Hacks |
| icemax |
![]() ![]() Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 ![]() | Nome Software: Google Hacks Direct Link al download: -Link- ![]() Dimensione File: 1,99 MB (2093308) Nome autore: Blue Shirt Studio eMail autore: -eMail- ![]() Sito Web Autore: -Link- ![]() Descrizione: Coltellino svizzero per il grandioso Google che in 1.99 mb ci permette di ricercare con pochi e semplici click : Libri, musica, files, torrent, file compressi di ogni tipo. il progetto non viola la licenza di Google poichè lo stesso programma e i suoi sorgenti sono ospitati su Google-Project. L'unica cosa : non usare questo programma per scopi illegali (data la potenza di ricerca che sfrutta i google-hacks) - Da provare e da inserire obbligatoriamente sulla nostra Winpenpack-compilation. Portable tips how-to: scaricare e decomprimere il file (ZIP) Versione:1.6 Licenza:GNU General Public License 2.0 screenshot : ![]() info originali : Google Hacks From Blue Shirt Jump to: navigation, search Google Hacks is a compilation of carefully crafted Google searches that expose novel functionality from Google's search and map services. For example, you can use it to view a timeline of your search results, view a map, search for music, search for books, and perform many other specific kinds of searches. You can also use this program to use google as a proxy. The name should not imply the way it should be used. Hacks is meant as this definition. "A Hack is a modification of a program or device to give the user access to features otherwise were unavailable to them. " Taken from Wikipedia Please do not use this program for illegal uses. If you have used this program to find a vulnerability or if your domain is being taken advantage of, we suggest you use Google Hacks Honey Pot [edit] New Make sure you use the firefox addon. -Link- ![]() Disclaimer -Link- ![]() Project Page -Link- ![]() Download -Link- ![]() Development Mailing List -Link- ![]() Links -Link- ![]() Retrieved from "http://www.blueshirt.info/index.php/Google_Hacks" potete trovare le altre versioni (anche per MAC) qui : -Link- ![]() * i sorgenti sono disponibili tramite svn un altro bel progetto sempre opensource della serie : GOOGLE-HACKs lo trovate qui : GHH V1.2 Honeypots -Link- ![]() [ Modificato sab 21 mar 2009 - 19:43 ] | ||
| Ketty |
![]() ![]() Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | icemax ha scritto ... Nome Software: Google Hacks nessun aggiornamento Test:a parte che il browser di default è internet Explorer, nulla da segnalare Non presente in Download [ Modificato sab 21 mar 2009 - 18:09 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 ![]() | Aggiunto al database -Link- ![]() | ||
