X-OpenOffice problem report |
JackL |
Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi, opening 2.0.0.3 X-OpenOffice I saw following comunicate: (not sure if you see that: "configuration data at file///X-OpenOffice/Bin/OpenOffice/share/uno_packages/cache/registry/com.sun.star.comp.deployment.configuration.PackageRegistryBackend/registry/data/org/openoffice/Office/UI/StarModuleWindowState.xcu is corrupted. Without this data some functions my not operate corectly." Any Idea what it can mean? I found StarModuleWindowState.xcu on the net but even after creation of all this folders (originally it ends with cache which is empty) and putting the file in, the communicate still apeared. thanks in advance | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Welcome to winPenpack In X-OpenOffice_2.3.0\Bin\OpenOffice\share\uno_packages\cache directory I have not any file. Did you try to delete registry/com.sun.star.comp.deployment.configuration.PackageRegistryBackend/registry/data/ org/openoffice/Office/UI/StarModuleWindowState.xcu ? Your SO is in english? [ Edited Tue 18 Sep 2007 - 18:20 ] | ||
Peter G |
Registered Member #5718 Joined: Tue 14 Aug 2007 - 21:38Posts: 21 | Just an idea: OOo has - I think in general - problems with "long" directory paths ....... Your error-message is remembering me to problems I had ...... How long is the directory path - what means, how many directories/subdirectories are between C: and the place where you have placed X-Openoffice ? From a certain "lenght" and number of subdirectories, OOo is unable to work ...... | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3359 | Hi JackL, I think Peter G, is on the right way. I had a similar issue in the past (long time ago) with a OOO (not portable) installed in a Long paht subdir. I don't remember at all wich was the alert message...... But also Danix is right! Also my "X-OpenOffice/Bin/OpenOffice/share/uno_packages/cache/" folder is completely empty! During program use the right pathname MUST be: "X-OpenOffice\User\OpenOffice\user\uno_packages\cache\registry\com.sun.star.comp.deployment.configuration.PackageRegistryBackend\registry\" but also this one in my version is completely empty so, this is a strange behaviour. Let us know if You solve the problem. | ||
JackL |
Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi Guys, I think the missunderstunding occured - in my X-OpenOffice also cache folder was empty but at first running attached above comunicate rised so my first idea as that my zip archive lost rest of the folders from communicated path - unfortunately there was no .xcu files in ziped package - then I created myself rest of the requested folders and found xcu file on the net - but the same comunicate is shown still at every running. My suspition is that there should be some call to this .xcu document inside OO, but I'm not a coder to find it outside of GUI options tool I hope I clarified a litle bit the situation - any Idea of the resolution? Anybody had the same issue? | ||
JackL |
Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi again, I am pleased to annonce that mentioned problem dissapeared after moving app from c onto pendrive - there should be seed of truth in information above about OO problems with long paths, however it still do not explained it's call to .xcu file - perhaps it could be reasonable to check the issue and to get know what a mysterious file reffer to? best regards | ||
