Aggiornamento: Miranda Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.9.27 Link winPenPack Aggiornamento dalla versione 0.9.26 alla 0.9.27 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Miranda 0.9.28 Link winPenPack Updated from version 0.9.27 to 0.9.28 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Result test: Not tested | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Miranda 0.9.29 Link winPenPack Updated from version 0.9.28 to 0.9.29 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Result test: Niente da segnalare scheda download aggiornata / download page updated [ Edited Tue 30 Aug 2011 - 11:54 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.9.30 Link winPenPack Updated from version 0.9.29 to 0.9.30 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- --- edit zandet2 --- Result test: Risultato test: niente da segnalare scheda download aggiornata [ Edited Tue 13 Sep 2011 - 10:03 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.9.31 Link winPenPack Updated from version 0.9.30 to 0.9.31 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download [ Edited Sun 09 Oct 2011 - 11:04 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.9.32 Link winPenPack Updated from version 0.9.31 to 0.9.32 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.9.33 Link winPenPack Updated from version 0.9.32 to 0.9.33 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download [ Edited Tue 01 Nov 2011 - 20:24 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.9.34 Link winPenPack Updated from version 0.9.33 to 0.9.34 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.9.35 Link winPenPack Updated from version 0.9.34 to 0.9.35 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.9.36 Link winPenPack Updated from version 0.9.35 to 0.9.36 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
