[Testing] Foxit Reader 2.2
alexcyber
Wed 03 Oct 2007 - 14:26
Registered Member #5886
Foxit Reader 2.2
ho trovato questa chiave nel registro:
HKLM\SOFTWARE\Classes\CLSID\{14E8BBD8-1D1C-4D56-A4DA-D20B75EB814E}\ProgID\: "FoxitReader.Document"
è normale?
ciao
[ Edited Sat 09 Feb 2008 - 23:48 ]
Wed 03 Oct 2007 - 14:52
Secondo me è una traccia trascurabile...
alexcyber
Sat 09 Feb 2008 - 10:45
stò usando x-foxit reader 2.2 su winxp e ho trovato queste chiavi:
[HKEY_CURRENT_USER\Software\Foxit Software]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\BookmarkFont]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\ChildFrame]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\DockState_PRO]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\FrameWnd]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\LANGUAGE]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\MainFrame]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\Measuring]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\pv_FindInfo]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\Settings]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\SnapShot]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\tv_FindInfo]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\tv_ReplaceInfo]
[HKEY_CURRENT_USER\Software\Foxit Software\Foxit Reader\Typewriter Preference]
foxitreader.zip
Sat 09 Feb 2008 - 11:25
Hai provato a cancellare la chiave HKEY_CURRENT_USER\Software\Foxit Software e a riavviare X-Foxitreader?
E' probabile che quella fosse una chiave relativa a una vecchia installazione del programma.
Fri 07 Aug 2009 - 10:24
Ho provato FoxitReader 3.0 Build 1301 -Link- + X-FoxitReader launcher 1.3 ( -Link- ).
Questi i log di due SO differenti, con delle chiavi molto probabilmente non rilevanti:
logfoxit_xp_sp2.zip logfoxit_xp_sp3.zip
Inoltre, di default, è selezionato l'aggiornamento software automatico che è possibile disattivare in due modi:
- o via interfaccia andando in
'Help' / 'Controlla aggiornamenti' (negando il consenso tramite firewall) / 'Preferences' / (togliendo il segno di spunta a) 'Automatically check for Foxit Updates'
- oppure modificando il file 'FoxitReader_Preferences.ini' mettendo il valore '0' in:
[AutoUpdate Info]
IsAutoUpdate=0
[ Edited Fri 07 Aug 2009 - 10:28 ]
