![]() Go to page << >> |
Darklight79 |
![]() ![]() ![]() Registered Member #1005 Joined: Thu 25 Jan 2007 - 16:48Location: Cesena (FC) Posts: 111 | Artweaver 0.5.5 Win2000, XP, Vista Link winPenPack Aggiornamento dalla versione 0.5.3 alla 0.5.5 Home: -Link- ![]() Direct Link: -Link- ![]() Italian language: -Link- ![]() Risultato test: Non testato [ Edited Mon 29 Sep 2008 - 17:07 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Artweaver 0.5.6 Win2000 , XP, Vista Link winPenPack Aggiornamento dalla versione 0.5.5 alla 0.5.56 Home: -Link- ![]() Direct Link: -Link- ![]() Italian language: -Link- ![]() Risultato test: niente da segnalare [ Edited Tue 18 Nov 2008 - 22:07 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Artweaver 0.5.7 Win2000, XP, Vista Link winPenPack Aggiornamento dalla versione 0.5.6 alla 0.5.5.7 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: niente da segnalare [ Edited Mon 22 Dec 2008 - 00:04 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Artweaver 1.0 Link winPenPack Aggiornamento dalla versione 0.5.7 alla 1.0 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: Not Portable Spoiler: [ Edited Sun 04 Oct 2009 - 16:17 ] | ||
Ketty |
![]() ![]() Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Ciao Rcs, ho provato con la procedura descritta da Ziozione qua -Link- ![]() ossia estrarre con universalextractor e creare il file Artweaver.ini con
[Settings]
Sembrerebbe funzionare, non rilevo nulla nel registro e il profilo viene salvato nella directory del programma. Ovviamente da confermare ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Ciao Ketty, hai ragione, così funziona! ![]() Portable tips how-to: estrarre il setup con Universal Extractor ed eliminare tutto tranne la cartella {app}, che può essere rinominata a piacere. Prima di avviare "Artweaver.exe" creare il file Artweaver.ini all'interno della directory del programma col seguente contenuto: [Settings] LangFilePath=Languages\Artweaver_en.lng [ Edited Sun 04 Oct 2009 - 16:16 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Artweaver 1.0.6 Link winPenPack Aggiornamento dalla versione 1.0 alla 1.0.6 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: Identico alla versione precedente [ Edited Tue 17 Nov 2009 - 15:17 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Artweaver 1.1 Link winPenPack Aggiornamento dalla versione 1.0.6 alla 1.1 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: Identico alla versione precedente | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Artweaver 1.22 Link winPenPack Aggiornamento dalla versione 1.1 alla 1.22 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: Identico alla versione precedente [ Edited Mon 11 Oct 2010 - 15:29 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Artweaver 3.0 Link winPenPack Aggiornamento dalla versione 1.2 alla 3.0 Home: -Link- ![]() Direct Link: -Link- ![]() Language ![]() ![]() Language files: -Link- ![]() Seguire le istruzioni della pagina download [ Edited Tue 22 Nov 2011 - 21:03 ] | ||
