![]() Go to page << >> |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Audacity 2.1.0 Link winPenPack Aggiornamento dalla versione 2.0.6 alla 2.1.0 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Audacity 2.1.1 Link winPenPack Aggiornamento dalla versione 2.1.0 alla 2.1.1 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Audacity 2.1.2 Link winPenPack Aggiornamento dalla versione 2.1.1 alla 2.1.2 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Audacity 2.1.3 Link winPenPack Aggiornamento dalla versione 2.1.2 alla 2.1.3 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() | ||
Bourne |
![]() ![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 ![]() | Provata la 2.2.0. Anche con il launcher 1.5.4 viene scritto (almeno qua su windows 8.1 pro x64 su standard account): c:\Users\<USER>\AppData\Local\Application Data\Audacity\ c:\Users\<USER>\AppData\Local\Application Data\Audacity\SessionData\ Ciao tutti. [ Edited Sat 04 Nov 2017 - 17:02 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | X-Audacity 2.3.0 Link winPenPack Aggiornamento dalla versione 2.2.0 alla 2.3.0 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Bourne wrote ... Provata la 2.2.0. Anche con il launcher 1.5.4 viene scritto (almeno qua su windows 8.1 pro x64 su standard account): c:\Users\ c:\Users\ Ciao tutti. Strano, a me non succede. Prova la 2.3.0 | ||
eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2127 ![]() | X-Audacity 2.4.0 Link winPenPack Aggiornamento dalla versione 2.3.0 alla 2.4.0 Home: -Link- ![]() Direct Link: (not portable) (LINK RIMOSSO) [ Edited Wed 20 May 2020 - 09:40 ] | ||
eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2127 ![]() | X-Audacity 2.3.3 Link winPenPack Aggiornamento dalla versione 2.3.0 alla 2.3.3 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() RETTIFICA IMPORTANTE A causa di un grave bug riscontrato nella versione 2.4, la distribuzione dello stesso è stata momentaneamente sospesa e sostituita con la versione 2.3.3. Si aspettano maggiori informazioni in merito al tipo di bug riscontrato. | ||
eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2127 ![]() | X-Audacity 2.4.1 Link winPenPack Aggiornamento dalla versione 2.3.3 alla 2.4.1 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() | ||
