X-OrbitDownloader !!PROBLEM!! |
snj_winpenpack |
Registered Member #7129 Joined: Sat 17 Nov 2007 - 15:01Posts: 4 |
Hi! I have problem with X-OrbitDownloader, first, reason for using this App is, because I'm using PC is a different kind of one, that PC has setup like read-only, whole OS partition and OS is like read-only, thing is we can save file change setting on OS, can do everything like normal PC, but after restart the machine, every thins like previous. So, that way comes to X-OrbitDownloader, but even though X-Orbit work as a normal Orbit, when next time I start the X-Orbit, Downloading list of previous moment, (means before restart) are, got Vanished, incomplete downloads are on the Download folder, with (.ob!). but those are not showing on the X-Orbit. Somebody Explain Me, Why? | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Welcome to winPenPack I think it's a bug The problem refers to \User\Orbit\unfinish.dat file and absolute paths... I'll try to fix it. [ Edited Sat 17 Nov 2007 - 16:15 ] | ||
snj_winpenpack |
Registered Member #7129 Joined: Sat 17 Nov 2007 - 15:01Posts: 4 | Got it! I Just made some Experiment why is that happening, 1. i made a link to download and pause it, exit from the sys tray, and starts again, paused file is haven't vanished. 2. by keeping that previous link in pause and, i made another link, paused downloading it and, I have opened the "Task Manager" and i end the task XOrbit. 2nd file has got vanished, and 1st one is their. normally this kind of thing never happen on App like GetRight, so i think this is a Orbit App makers fault. ThanX. | ||
snj_winpenpack |
Registered Member #7129 Joined: Sat 17 Nov 2007 - 15:01Posts: 4 | i think this is a Orbit App makers fault. i just try it on normal orbit, thair is no problem with that, so i think problem is on X-Orbit, not on normal orbit. | ||
snj_winpenpack |
Registered Member #7129 Joined: Sat 17 Nov 2007 - 15:01Posts: 4 | actually something serious happened to me with that problem, i were downloading apple .mov trailers that moment, and while downloading x-orbit got closed by without a proper exiting, so as i say, when next time I start the X-Orbit downloading list got vanished, and then I have completed the file by importing through broken downloads. and finally while playing those videos, get stucked in the middle. | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Sorry, but now we consider the program NOT Portable -Link- However, we will continue with testing... [ Edited Sat 24 Nov 2007 - 16:10 ] | ||
