Aggiornamento: X-RSSOwl Go to page << |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-RSSOwl 2.0.4 Link winPenPack Aggiornamento dalla versione 2.0.3 alla 2.0.4 Home: -Link- Direct link (not portable): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-RSSOwl 2.0.5 Link winPenPack Aggiornamento dalla versione 2.0.4 alla 2.0.5 Home: -Link- Direct link (not portable): -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Sat 11 Sep 2010 - 14:53 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-RSSOwl 2.0.6 Link winPenPack Aggiornamento dalla versione 2.0.5 alla 2.0.6 Home: -Link- Direct link (not portable): -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Mon 11 Oct 2010 - 22:23 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-RSSOwl 2.1 Link winPenPack Aggiornamento dalla versione 2.0.6 alla 2.1 Home: -Link- Direct link (not portable): -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Mon 01 Aug 2011 - 21:49 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | X-RSSOwl 2.1.2 Link winPenPeck Update from version 2.1 to version 2.1.2 Home: -Link- Direct link (not portable): -Link- --- edit zandet2 --- software wpp aggiornato | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-RSSOwl 2.1.4 Link winPenPeck Update from version 2.1.2 to version 2.1.4 Home: -Link- Direct link (not portable): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-RSSOwl 2.1.6 Link winPenPeck Update from version 2.1.4 to version 2.1.6 Home: -Link- Direct link (not portable): -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Wed 20 Mar 2013 - 21:45 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-RSSOwl 2.2 Link winPenPeck Update from version 2.1.6 to version 2.2 Home: -Link- Direct link (not portable): -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Sun 26 May 2013 - 22:05 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-RSSOwl 2.2.1 Link winPenPeck Update from version 2.2 to version 2.2.1 Home: -Link- Direct link (not portable): -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Tue 21 Oct 2014 - 23:15 ] | ||
Blackcrack |
Registered Member #41707 Joined: Sat 28 Dec 2013 - 08:45Posts: 29 | Hi, easy, download the RssOWL ZIP -> go into rssowl -> configuration -> edit config.ini -------original----------/RssOWL/configuration/config.ini------------------------
[old/original]
--------------------------/RssOWL/configuration/config.ini--------original------- ------portable-----/RssOWL/configuration/config.ini------------------------
[new, make it portable]
--------------------------/RssOWL/configuration/config.ini--------portable------- now can you add an folder named "jre" and put in the portable Java .. ( /RssOWL/jre/lib & /RssOWL/jre/bin & etc ) and there can you add an installable Xulrunner 1.9 or you add via Variables with X-portable-Starter an own XulRunner folder with the newest XulRunner from Mozillas XULRunner and use this as static webbrowser engine in Rssowl for displaying the webwebsites .. if it configurate for display the Webpages directly for customizing for WinPenPack, edit the bmp-picture and add "portable by WinPenPack" and rename the exe as X-RssOwl best regards Blacky [ Edited Wed 01 Jan 2014 - 10:48 ] | ||
Go to page <<
