Aggiornamento: X-VideoLANGo to page << >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-VideoLAN 1.0.1 Link winPenPack Aggiornamento dalla versione 1.0.0 alla 1.0.1 Home: -Link- ![]() Direct link : not portable -Link- ![]() [ Edited Mon 03 Aug 2009 - 17:11 ] | ||
| sceicco |
![]() ![]() Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | X-VideoLAN 1.0.2 Link winPenPack Aggiornamento dalla versione 1.0.1 alla 1.0.2 Home: -Link- ![]() Direct Link: not portable -Link- ![]() [ Edited Thu 24 Sep 2009 - 19:56 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-VideoLAN 1.0.3 Link winPenPack Aggiornamento dalla versione 1.0.2 alla 1.0.3 Home: -Link- ![]() Direct Link: not portable -Link- ![]() [ Edited Sun 31 Jan 2010 - 19:30 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-VideoLAN 1.0.5 Link winPenPack Aggiornamento dalla versione 1.0.3 alla 1.0.5 Home: -Link- ![]() Direct Link: not portable -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Fri 19 Feb 2010 - 20:57 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-VideoLAN 1.1.0 Link winPenPack Aggiornamento dalla versione 1.0.5 alla 1.1.0 Home: -Link- ![]() Direct Link: not portable -Link- ![]() | ||
| thunder |
![]() ![]() Registered Member #2817 Joined: Fri 16 Feb 2007 - 19:58Posts: 10 | E' passato tanto tempo dal rilascio della versione 1.1.0, non avete più intenzione di aggiornare questo magnifico lettore? ![]() | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | L'intenzione c'è, ma le difficoltà sono diverse: anche se il cambio di versione sembra minimo (da 1.0.5 a 1.1) in realtà la struttura interna del programma è stata decisamente modificata, quindi bisogna aggiornare e ritestare di conseguenza a fondo il launcher prima di rilasciarlo... Ciao! | ||
| Vecna |
![]() ![]() Registered Member #8113 Joined: Fri 11 Jan 2008 - 12:37Posts: 18 | Complimenti! Una cura nel rilascio davvero encomiabile! ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | zandet2 wrote ... L'intenzione c'è, ma le difficoltà sono diverse: anche se il cambio di versione sembra minimo (da 1.0.5 a 1.1) in realtà la struttura interna del programma è stata decisamente modificata, quindi bisogna aggiornare e ritestare di conseguenza a fondo il launcher prima di rilasciarlo... Sto provando la nuova versione e, a parte un problema di cache (un file *.cache-2 salvato in %AppData%\vlc che deve essere trasportato da \User\VideoLAN\settings\ a %AppData%\vlc\, e viceversa, ad ogni esecuzione del programma), il launcher sembra abbastanza compatibile. La cosa migliore è creare una versione beta da inserire nella sezione "Beta versions" del forum. Appena posso apro un nuovo topic. --- edit ---- C'è anche un problema nei file .xspf che contengono le "scalette" salvate. Per correggere i percorsi il launcher v1.4 non è sufficiente. Occorre quello modificato usato per DVDStyler.[ Edited Thu 08 Jul 2010 - 17:10 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Danix wrote ... La cosa migliore è creare una versione beta da inserire nella sezione "Beta versions" del forum. Dal momento che i test scarseggiano, non vale la pena creare un topic apposito nella sezione "Beta release". Ho aggiornato direttamente in download con questo change log:
- eliminata copia impostazioni predefinite per disabilitare gli aggiornamenti automatici (x-default)
Se qualcuno incontrasse problemi, ce lo faccia sapere. Danix wrote ... C'è anche un problema nei file .xspf che contengono le "scalette" salvate. Per correggere i percorsi il launcher v1.4 non è sufficiente. Occorre quello modificato usato per DVDStyler. @Sviluppatori/portabilizzatori:
Problema normalizzazione percorsi assoluti nei file delle playlist (risolto
