Modifiche e aggiornamenti software da winPenPack 3.3 Go to page << >> |
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Se l'esito dei test è positivo, sostituirà X-SharkTorrent: X-Halite 0.3.0 -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Fix X-VideoLAN 0.8.6d [rev2] Fixed: -Link- Dettagli: -Link- [ Edited Wed 16 Jan 2008 - 21:02 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | MediaCoder 0.6.1.4031 Link winPenPack Aggiornamento dalla versione 0.6.1.4030 alla 0.6.1.4031 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Ditto Portable 3.15.4.0 Link winPenPack Aggiornamento dalla versione 3.15.1.0 alla 3.15.4.0 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Stellarium 0.9.1 Link winPenPack Aggiornamento dalla versione 0.9.0 alla 0.9.1 Home: -Link- Direct link: -Link- [ Edited Fri 18 Jan 2008 - 14:48 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-WinMerge 2.6.14 Link winPenPack Aggiornamento dalla versione 2.6.12 alla versione 2.6.14 Home: -Link- Direct Link: not portable -Link- [ Edited Fri 18 Jan 2008 - 14:47 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: Regshot 2.0.1-33 Aggiornamento dalla versione 1.8.2 alla 2.0.1-33 Home: -Link- Direct link: -Link- [ Edited Mon 04 Feb 2008 - 17:52 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: Extreme Tux Racer 0.4 Aggiornamento dalla versione 0.35 alla 0.4 Home: -Link- Direct Link: -Link- | ||
Darklight79 |
Registered Member #1005 Joined: Thu 25 Jan 2007 - 16:48Location: Cesena (FC) Posts: 111 | X-ClamWin 0.92 Link winPenPack Aggiornamento dalla versione 0.91.2 alla versione 0.92 Home: -Link- Direct Link: (not portable) -Link- [ Edited Mon 21 Jan 2008 - 14:45 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Gimp 2.4.3 Link winPenPack Aggiornamento dalla versione 2.4.2 alla 2.4.3 Home: -Link- Direct Link: -Link- [ Edited Thu 24 Jan 2008 - 13:45 ] | ||
