[MUSIC Utility] Mixxx |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | Nome Software:Mixxx Direct Link al download: -Link- Dimensione File: 15.1 MB (15868051) Nome autore: Ken & Tue eMail autore: (vedi sotto ) Sito Web Autore: -Link- Descrizione: Mixxx è un tool per DJ open source. Permette il mixaggio di brani (tamite mouse) in modo molto agevole tramite un'interfaccia grafica molto carina. Mixxx visualizza le trecce in modo parallelo e supporta diversi tipi di hardware per DJ e non. Pieno supporto per controllers MIDI. Supporta quasi tutti i formati audio più diffusi quali : MP3, Ogg Vorbis, e Wave Mixxx supporta il drag&Drop dei files e delle playlists : M3U PLS . Portable tips how-to: scaricare questo launcher e seguire le istruzioni -Link- Versione:1.5.0 Licenza:GPL 2 codice sorgente scaricabile da QUI. screenshot : info originali : Mixxx is an open source DJ tool designed for both professional and amateur DJs alike. Mixxx allows DJs to mix music live with a clean, simple interface. Futhermore, Mixxx has a number of key features to help DJs in the mix: Beat estimation, parallel visual displays, and support for various DJ hardware controllers Mixxx reads most popular sound formats, including MP3, Ogg Vorbis, and Wave. For communication, Mixxx supports MIDI controllers along with standard input devices such as joysticks and mice Mixxx is available on all major desktop operating systems, including Windows (XP and Vista), Linux and OS X. Mixxx is also open source, so it can be downloaded and used for free. Mixxx is distributed under the GPL. Mixxx is designed with a strong focus on interaction. Mixxx is easy to use for novice and professional DJ's, including live performances. Import M3U and PLS playlists from any program, as well as drag-and-drop tracks right into Mixxx Credits : Mixxx was started by Ken and Tue Haste Andersen. Today, the primary development is done by Adam Davison, along with many open source developers from around the world: Maintainer: Adam Davison Mac/Linux Maintainer: Albert Santoni Skins: Ludek Horácek (Traditional) Tue Haste Andersen (Outline) Ogg Vorbis support: Svein Magne Bang Beat tracking: Tue Haste Andersen Kristoffer Jensen Playlist import: Ingo Kossyk Beat phase sync: Torben Hohn ALSA support: Peter Chang SoundTouch support: Mads Holm Spiffy icons: Tango Project Other contributions: Lukas Zapletal Garth Dahlstrom Ben Wheeler Jeremie Zimmermann Tim Jackson Gianluca Romanin Jan Jockusch Frank Willascheck Special thanks to: Adam Bellinson Mixxx also depends on a number of libraries. Without these, Mixxx would not be possible, especially as a cross-platform application. Lastly, we'd like to thank the many musicians and DJ's that have helped in designing Mixxx. [ Edited Tue 18 Dec 2007 - 01:05 ] | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Ice il file che hai indicato nel download mi porta ad un .exe che va scompattato con universal extractor. Una volta lanciata l'applicazione lascia le seguenti tracce: C:\Documents and Settings\nome_utente\mixxx.cfg C:\Documents and Settings\nome_utente\mixxxtrack.xml | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Decomprimere l'archivio ZiP allegato >> inserire il programma in X-Mixxx\Bin\mixxx >> avviare X-Mixxx.exe x-mixxx.zip [ Edited Tue 18 Dec 2007 - 01:10 ] | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Cioè hai già creato l'ini? Sei sempre mitico | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | X-Mixxx (portabilizzato) -Link- Spostare in Sviluppo | ||
