Modifiche e aggiornamenti software da winPenPack 3.3 Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Virtual Magnifying Glass 3.3.1 Link winPenPack Aggiornamento dalla versione 3.3 alla 3.3.1 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | MediaInfo 0.7.5.6 Link winPenPack Aggiornamento dalla versione 0.7.5.5 alla versione 0.7.5.6 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-EasyTag 2.1.4 Beta Link winPenPack Aggiornamento dalla versione 2.1.3 Beta alla versione 2.1.4 Beta Home: -Link- Direct Link: (not portable) -Link- [ Edited Fri 14 Dec 2007 - 08:51 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | MediaCoder 0.6.0.3996 Link winPenPack Aggiornamento dalla versione 0.6.0.3993 alla 0.6.0.3996 Home: -Link- Direct Link: -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | X-OpenOffice Bug Fix (ini only) x_ooo_ini.zip | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-PokerTH 0.6 Link winPenPack Aggiornamento dalla versione 0.6-rc2 alla 0.6 Home: -Link- Direct link: not portable -Link- [ Edited Fri 14 Dec 2007 - 18:48 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | MediaCoder 0.6.0.3998 Link winPenPack Aggiornamento dalla versione 0.6.0.3996 alla 0.6.0.3998 Home: -Link- Direct Link: -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Nuovo inserimento winPenPack 1Gb - School X-Jreepad 1.5 -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Se questo bug viene confermato, NON bisogna comprimere InfraRecorder con UPX. X-InfraRecorder 0.44.1 [no_UPX rev3] -Link- | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: X-IpScan 3.0-beta1 non ancora aggiornato... Aggiornamento dalla versione 2.21 alla 3.0-beta1 Home: -Link- Direct Link: not portable -Link- [ Edited Sat 22 Dec 2007 - 21:56 ] | ||
