Aggiornamento: X-MixxxGo to page << |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.9.0 Link winPenPack Aggiornamento dalla versione 1.8.2 alla 1.9.0 Home: -Link- ![]() Direct link (not portable): -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Sat 04 Jun 2011 - 13:03 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.9.2 Link winPenPack Aggiornamento dalla versione 1.9.0 alla 1.9.2 Home: -Link- ![]() Direct link (not portable): -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Mon 14 Nov 2011 - 22:56 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.10.0 Link winPenPack Aggiornamento dalla versione 1.9.2 alla 1.10.0 Home: -Link- ![]() Direct link (not portable): -Link- ![]() --- edit zandet2 --- software wpp aggiornato nota: da questa versione il software diventa multilingua nativo [ Edited Fri 01 Jun 2012 - 21:48 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.10.1 Link winPenPack Aggiornamento dalla versione 1.10.0 alla 1.10.1 Home: -Link- ![]() Direct link (not portable): -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Tue 14 Aug 2012 - 08:20 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.11.0 Link winPenPack Aggiornamento dalla versione 1.10.1 alla 1.11.0 Home: -Link- ![]() Direct link (not portable): -Link- ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 2.0 Link winPenPack Aggiornamento dalla versione 1.11.0 alla 2.0 Home: -Link- ![]() Direct link (32 bit): (not portable) -Link- ![]() Direct link (64 bit): (not portable) -Link- ![]() | ||
| eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2267 ![]() | X-Mixxx 2.2.3 Link winPenPack Aggiornamento dalla versione 2.0 alla 2.2.3 Home: -Link- ![]() Direct link (32 bit): (not portable) -Link- ![]() Direct link (64 bit): (not portable) -Link- ![]() Per chi fosse interessato, la versione precedente è la 2.1.8 scaricabile da questi link 32 bit 64 bit Per chi volesse sperimentarla, c'è anche la versione beta2.3.0 scaricabile da questo link 64 bit Come avete notato la versione 2.3.0 è solo a 64 bit. chi volesse una versione compatibile con i 32 bit deve usarela 2.2.3 [ Edited Wed 17 Jun 2020 - 11:25 ] | ||
Go to page <<
