PDF-XChange Viewer Portable 1.0031Go to page << |
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | tDJ, thank you, I have updated in the download section. But the update has been already submitted -Link- ![]() Please, use THIS FORUM SECTION for signal an update. Before to signal a new software or update, you must search if the software (or update) is already present in our database. Thank you. | ||
| tDJ |
![]() ![]() ![]() Registered Member #9527 Joined: Fri 07 Mar 2008 - 17:36Posts: 12 | Danix wrote ... But the update has been already submitted -Link- ![]() Please, use THIS FORUM SECTION for signal an update. Before to signal a new software or update, you must search if the software (or update) is already present in our database. Well, I did a search. But it seems I did it in the wrong forum. Sorry. | ||
| pegasocv |
![]() ![]() Registered Member #6449 Joined: Wed 10 Oct 2007 - 21:16Posts: 433 ![]() | Ottimo programma, veramente ben fatto!!! ----edit---- Il file HELP è valido anche per l'ultima versione? Dove lo devo incollare nella cartella? Sapete se si possono creare nuovi timbri e se si come fare? ![]() [ Edited Thu 13 Mar 2008 - 22:50 ] | ||
| claupilli |
![]() ![]() Registered Member #9513 Joined: Fri 07 Mar 2008 - 12:48Posts: 60 | Anche a me servirebbe sapere se si possono creare nuovi timbri e come fare!!! ![]() | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | claupilli wrote ... Anche a me servirebbe sapere se si possono creare nuovi timbri e come fare!!! Semplicemente andando sul sito del produttore e acquistando la versione PRO -Link- ... | ||
| pegasocv |
![]() ![]() Registered Member #6449 Joined: Wed 10 Oct 2007 - 21:16Posts: 433 ![]() | Grazie zandet2 Comunque ultimamente questo programma è in pieno sviluppo. Cosa molto bella ed utile... ![]() | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | pegasocv wrote ... Grazie zandet2 Era una battuta... | ||
| deep |
![]() ![]() ![]() Registered Member #7 Joined: Sat 20 Jan 2007 - 20:57Posts: 568 ![]() | pegasocv wrote ... Comunque ultimamente questo programma è in pieno sviluppo. Cosa molto bella ed utile... Difatti l'ho sostituito a Foxit e devo dire che mi trovo piuttosto bene. E' altrettanto agile e, sebbene sia lievemente più pesante in termini di spazio occupato rispetto a X-Foxit, compensa col fatto che non necessita di un launcher. | ||
| pegasocv |
![]() ![]() Registered Member #6449 Joined: Wed 10 Oct 2007 - 21:16Posts: 433 ![]() | zamdet2 Si ho capito, ma comunque mi hai detto come fare... sai io con l'inglese ho litigato tanti anni fa... Già che mi ricordo, ma anche la versione pro è no install? ![]() [ Edited Sat 15 Mar 2008 - 13:19 ] | ||
Go to page <<
